I just found out my rear end is toast in my 09' f250 so I need a replacement needs to be limited slip with 3.73's with fairly low miles. I am in MD near DE and PA pickup would be best to save time as I need it quickly!
May I ask what happened?
Sent from my DROIDX using AutoGuide.Com Free App
I post in the driveline section that i had a abs issue come to find out about all the ring gear bolts backed out and took out the speed ring and sensor not to mention the carrier and probably the ring gear threads but all the teeth seemed fine!
Man sorry to hear. Are you needing the entire axle or just diff and ring/pinion?
Just the carrier/gears /bearings housing and axles seem to be fine but a complete rear would speed things up!
