Hi All, I'm looking for an 05-07 F350 front sway bar. If you have one (hopefully local in CA), let me know. Thanks
ZMANN · Administrator Joined Feb 5, 2008 · 35,574 Posts #2 · 8 mo ago Only show this user if you really need a sway bar I would upgrade to a better than OEM unit the factory bar is pretty light duty
G GlamisPSD · Registered Joined Mar 5, 2008 · 88 Posts Discussion Starter · #3 · 8 mo ago Only show this user Any recommendations?
G GlamisPSD · Registered Joined Mar 5, 2008 · 88 Posts Discussion Starter · #4 · 8 mo ago Only show this user I forgot to mention….I just did a PMF 4-link conversion with a 2012 D60 so fitment has not been straight forward. PMF said they would use an 05-07 bar
ZMANN · Administrator Joined Feb 5, 2008 · 35,574 Posts #5 · 8 mo ago Only show this user ohhh you did a coil swap on an older truck I can see why the 05-07 swaybar was recommended the frame's change pretty drastically up front after that you will just be looking for end links that are appropriate ,, for the 2012 / 2005 mix Hellwig is a common aftermarket unit and what I run
ZMANN · Administrator Joined Feb 5, 2008 · 35,574 Posts #6 · 8 mo ago Only show this user you can do some custom spacers and probably retrofit this bad boy Ford F550 Front Sway Bar - auto parts - by owner - vehicle... Ford F550 front sway bar with frame moints. Removed from vehicle after about 500 miles. Will fit 2011-2022 trucks. Price is negotiable. orangecounty.craigslist.org he won't ever sell that IMO so lowball him
