Write Up: Power Potential of the 6.0L PSD
150655 Views 76 Replies 37 Participants Last post by  Canadian Mind
Purpose of this Thread:
The purpose of this thread is show what a 6.0L Powerstroke is capable of in a daily driver level build, without excessive debate over individual components and practices. The daily driver builds outlined below all allow for some form of towing, either as they are or as a result of aftermarket tuning restricting fueling of the injectors.
I do not build race trucks, nor am I a mechanic. I own a 6.0L/5R110 setup and found that I have a considerable amount of notes on the subject that other members of the ORG may benefit from. These are not the end-all setups for a particular powerband, but instead a starting point for those who are looking to get the most of their 6.0L.
What I need form other ORG Members:
I will always be looking to improve this thread. As technology advances and breakthroughs are made (for example the recent advancements in 6.0L turbos, and FICM tuning), I will revisit this thread and update it accordingly.
Scope of this Thread:
Limiting this thread to the builds using a single VGT style turbocharger, and aftermarket injectors up to 205cc. Again, these are daily driver builds, which the single VGT turbo lends itself to be reliable. Tuning will be limited in the scope of my discussion to SCT custom files flashed via an SF3 or X3 tuner, and the recent development of FICM tuning.
Do to the various factory strategies and variables of trucks between the years of production between '03-'07, no particular setup will produce the exact same results for every truck. Again this thread's intention is to be a starting point for that 6.0L owner who has a grasp of the motors shortfalls, and bullet-proofing requirements, looking to get to a certain power level.
Furthermore, these builds will be under the concept of Fuel Only. At least until such a point I have collected enough data to justify the application of Nitrous, and Water/Methenol systems to this discussion.
Organization of Builds:
This thread will be broken down first by power level achievable through Electronic Tuning alone. Followed by specific sections focused on a particular Injector size. The reason behind this, is the dependency of matching the injector to your turbocharger. The supporting modifications for any one build are more centered upon the choice of fuel injector than
any other upgrade.
Initial Conditions:
First step in any of these builds will be the installation of a Monitor Package / Gauges that will allow for the owner to prevent the major shortfalls of the 6.0L from becoming major failures. This will also allow the owner to keep an eye on the details of what the major systems under the hood are operating correctly, and what will require service/repair. Before
tuning the following subsystems must be verified:
-Coolant flow through the Oil Cooler, and EGR Cooler
-FICM Performance
-Fuel Delivery to the Injectors
When the goal will be to break 400RWHP, considerations should be made to the next level of Bullet-Proofing. This may or may not include the installation of Head Studs, or the External Oil Cooler systems, however all Model Year flaws should be addressed, the EGR Cooler should be solved, the the Fuel Pressure Regulator should have the updated spring.
http://www.powerstroke.org/forum/ge...204386-write-up-bullet-proofing-6-0l-psd.html
Studs in my mind are a preventive measure up to around 400RWHP, at which point the tuning is advanced enough to stretch the stock bolts leading to failure. Most tuners have stock bolt level files, which I won't go into much detail about. When you set your goals above 400-425RWHP, you short change your programming, and reliability by not doing a full head stud job. This should include the following:
-Having the head studs themselves installed.
-Use of OEM Head Gaskets.
-Having the Heads themselves taken to a shop to be tested, checked, and ensured flat. Even new OEM replacements have such
a tolerance leaving the factory, that new heads should be checked as well.
-Have the Oil Cooler rebuilt/replaced (you're already this far in the motor), and ensure your EGR solution is holding up.
Base Line - Stock Power Levels:
Stock Programming from Ford is Rated for 325HP/560-570Ft-Lbs at the crank, which depending on the truck and gearing leads to a conservative estimate of 270HP/490Ft-Lbs at the rear wheels. For these discussions I'm only worried about the power put down at the rear wheels.
Breaking 500RWHP Modifications:
There are a number of components on the 6.0L Powerstroke drive train that are commonly taken as "good to 500HP." Though individual builds may address these later, I will take a moment to address a couple of key ones now:
-An aftermarket Cold Air Intake, simply isn't required for builds of this level. The stock Donaldson filter has been proven to 500RWHP, and filters better than anything on the market, maintaining the longevity of the turbocharger and valves.
-An aftermarket intake manifold elbow and cold IC pipe (only applies to '05+ trucks with the plastic IC pipe). These pipes commonly fail under high boost pressure conditions with larger than stock turbos.
-Stock components of the 5R110 Transmission, though this requires that you are using SCT programming, and no shift on the fly. The SCT tuners will actually adjust more parameters of the 5R110 transmission, then they will on the engine itself. The 5R110 is a solenoid-valve centered transmission (vise a valve-body like the 4R100 was). Where as the power handing potential is there, shift on the fly tuners rely on the transmission relearn protocols to adapt to the new power levels each time the power is changed. Each of these adaptations, lead to the possibility of damage from a bad shift, and will overtime shorten the life of your transmission. Written tunes align the transmission's expectations to the new power of the ECM tune, allowing for hundreds of thousands of miles of performance out of the stock internals with routine maintenance. What will need to be upgraded will depend on how far past that 500HP mark you take your build, and how hard you drive it.
-Either the turbocharger or the injectors will require replacement to break this plane of performance. I'll leave the particulars of these choices for the builds listed below.
Cold Air Intakes
There is a lot of debate about the cost-benefit ratio of upgrading the stock air filter and intake assemblies on the 6.0L. The old mindset was that the stock air filter was good to 500RWHP, and for the most part that is still correct. However once you building beyond the limits of electronic programming, you are limiting your gains by the stock box.
507RWHP was put down with 175's and the Powermax turbocharger, it was truck builds similar to this that gave folks the impression that the stock air filter can and will support builds upto that level of power. Depending on your driving evironment, and personal perferances, the stock filter may not be best for your 500RWHP build. Dusty areas, and dirt roads, situations were filtration is more important is were the stock filter surpasses anything on the aftermarket for filtration and protecting your investment.
When you look at the gains of these advanced builds being put together now. 485RWHP on an S&B intake, exhaust, stock injectors, and a Stage 2 turbo, with ECM/FICM tuning. (Only 22HP shy of that 175, Powermax, stock air box, ECM tuning only.) With the investment of a turbo or injectors (between $850-$3600, plus instalation), its pretty clear you are holding your build back with the stock air filter (roughly a $400 upgrade). There are two leading filter systems out there, the first is the S&B intake and the other is from AFE.
When you look at weather your build requires the addition of a cold air intake, look at that filtration to performance balance.
I found one good source on the subject, actually a set of test results from S&B, per ISO 5011 Air Filtration Standard. Great read here, and puts a lot of things into perspective:
NetSuite | Page Not Found (Will pop-up as a PDF, ignore the page not found)
A couple of key notes with these specific filters:
Capacity of Dirt:
S&B 75-5032 - 170.3
S&B 75-5032D - 136.2
Motorcraft (Stock) - 1304.1 (huge capacity for contaminants)
Flow Rates:
S&B 75-5032 - 39.16% improvement (on average)
S&B 75-5032D - 35.28% improvement (on average)
Motorcraft (Stock) - Base of this Test
Consider this: It only takes 170.3 grams of contaminants to provide the filter with enough restriction to pull 28"H2O per that test with the S&B 75-5032. That level of contamination is only 13% of the life cycle of the stock unit. Which will hold 1304 grams of contaminates before pulling the same 28"H2O.
I'm gonna keep looking for more of this type of data, from the other competitors. S&B took a good step here backing up the claims with about as solid a test as you can get.
Electronic Programming Only:
Supporting Modification for builds focused on Electronic Programming only:
-A 4" Turbo Back Exhaust, with either a 3.5" or 4" DP, and maintaining the CAT and Muffler as owner and local regulations dictate. The stock exhaust will be sufficient for daily driving, with minimal time is spent at WOT. I ran my files for several weeks with the stock pipes with no adverse effects, other than it didn't take long to reach 1250* EGT's at WOT.
370-400RWHP via tuning:
-Most of the street level programs offered today will fall under this powerband, and be able to tow upwards of 8K on stock head bolts. Street manners are very calm on trucks running this level of power, with smooth shifting of the transmission. Smoke is minimized or non-existent on most of these files.
400-425RWHP via tuning:
-The higher HP performance tunes from the tuners today market their files within this powerband. Towing of any kind is not recommended to to the amount of fueling involved and chance of damageing components / overheating. Depending on the build of these tunes, the transmission shifting may be smooth (street files) or much firmer (race files). Smoke at WOT is not uncommon, however when these files are ran for daily driving smoke is manageable.
Breaking 425RWHP via tuning alone:
-This will require the highest HP files from your tuner, with your goals clearly defined at the time the tune is written. Again, towing of any kind is not recommended. Transmission shifting tends to be firm on these files, as street manners play less of a factor. Smoke will be present with these files, as the tune is typically written to maximise fuel delivery,
which will exceed the supply of air delivered by the stock turbocharger.
-The second phase of this tuning, will effect the FICM. Files are now available in 40HP, 80HP, and 100HP over stock vareties (figures do not stack on top of aftermarket programs). A 80HP or better FICM tune is recommended for those who intend to push electronic tuning to its max. Again this will maximize fuel delivery under programming.
A great thread on the benefits of 58v vs. 48v:
http://www.powerstroke.org/forum/6-0l-performance-parts-discussion/264206-48v-vs-58v-ficm.html
Explaination of Aftermarket Injectors:
In regards to aftermarket injectors, what does the 'cc' value and '%' actually refer to?
First is the capacity of the injector spool itself. This value tells you how much fuel it holds, under the pressure of the fuel header. For baseline reference the stock units are around 135cc.
Second number is the percentage that the nozzles are bored over stock. This value is the relative improvement of how quickly that injector would drain the fuel held in its spool.
How do these numbers inter-relate?
Four factors will determine how much fuel will make it into your cylinder. 1) Injector Spool Size, 2) Nozzle Size, 3) Fuel Pressure, 4) Injector Pulse Width. If you have an injector that is stock, running the proper 65psi of pressure, and firing under a pulse width that empties that spool (135cc fuel delivered). Change the injector size, the other three held constant, you will still only deliver that 135cc charge based on fuel passing the same nozzle, pressure and timing (Yes even if running say a 190cc injector with stock nozzles, you will only deliever a stock level of fuel during the same pulsewidth- you will have more power on the low end when RPMs allow a longer PW, but under high RPMs the injector cant stay open long enough to deliver that fuel charge). Change the nozzle size, the other three held constant, and you will run out of fuel in the spool during the cycle. So as that example shows, one has to either match injector capacity with nozzle to allow the same tuning, or adjust tuning to maximize performance. What is done is normally a combination of both.
Here is a rough listing of what the general ratio is of injector capacity to nozzle size.
Stock: 135cc / Stock
Aftermarket: 155cc / 30%
Aftermarket: 175cc / 75%
Aftermarket: 190cc / 100%
Aftermarket: 205cc / 125%
There is one more marketing factor with aftermarket injectors, and thats the number of holes. The stock units, and most aftermarkets are 6 hole which will be more reliable in the long run (as less material is removed during the process). 8 hole injectors are offered by a few manuafacturers, and while the smaller individual hole allows for better atomization of
fuel leaving the nozzle, there is a balance of what is structurally better for the long run. Since this thread is for the daily driver level builds, we will only be looking at the 6 hole injectors.
Regardless of the aftermarket injector and turbo combination you select, tuning should be adjusted to maximize performance.
I'll get into this balance of Air / Fuel / Tuning, after we discuss turbos.
For further discussion, check the following thread:
http://www.powerstroke.org/forum/6-...on/250059-explanation-injector-cc-nozzle.html
Fuel Supply Systems:
As I mentioned these builds focus around the injectors, such as supporting mods are normally biased to the injector level. Fuel System upgrades are vitally important to ensure injector longevity, and performance. With stock or mild injectors the stock fuel system is capable of delivering the required 65psi during WOT. This is something to keep an eye on, however, and the installation of a regulated return system is recommended but not required for 155cc class injectors. Moving into the 175cc and 190cc Injectors, the stock fuel pumps become overburdened. This is where the aftermarket kits like the AirDog 2 start to come into play. Once you make the jump to 205cc injectors or above, you will need to talk directly with your injector supplier for their recommendations to ensure adequate fuel is available for your larger power demands.
HPOP is the other aspect for proper fuel delivery, and Injector Control Pressure is feed by the HPOP. For the builds discussed in this thread, an aftermarket upgrade of the HPOP is not required. Typically, injectors larger than 225cc is when one would start looking at these units, or as an alternative to replacing a stock unit that has failed.
Explanation of Aftermarket Turbochargers:
**Reserved for further discussion about specifics and relationship**
Stock Garrett Turbocharger: 58.0x82mm 0.58AR (10 blade for '03, and 13 blade for '04+)
Garrett Powermax Turbocharger: 63.5x88mm 0.58AR
Stage 1 Mad Turbo Werks: (Durastroke - LLY) 63.5x88mm 0.58AR (blade count dependent on provided turbo)
Stage 1 Mad Turbo Werks: (Durastroke - LBZ) 62.8x88mm 0.58AR (blade count dependent on provided turbo)
Stage 1 Mad Turbo Werks: (New Model) 63.5mmx88mm 0.58AR (13 blade).
Hybrid Mad Turbo Werks: 64.7x88mm 0.58AR (13 blade).
Stage 2 Mad Turbo Werks: 64.7x88mm 0.72AR (blade count dependent on provided turbo)
Stage 3 Mad Turbo Werks: (Under Development) 67.8x94mm .58AR
Stage 4 Mad Turbo Werks: (Under Development) 72.0x94mm .58AR
Elite Diesel Modified Powermax - SSX: 64.7x84mm 0.90AR
Elite Diesel Modified Powermax - HO: 67.8x94mm 0.90AR
Bringing the Three Together
High Performance Diesels are a balance of Air to Fuel ratio and programming. We have all seen those that blow nothing but smoke, it is what has given the diesel enthusiasts a bad reputation, and what tightens the regulations on these trucks with each passing year. Smoke is nothing more than unburt fuel, its not horsepower, its not impressive, and it isn't getting you down the track any faster. Causes of smoke (unburnt fuel): 1) Insufficient Airflow/Boost. 2) Overly Tuned Injectors. 3) Poor Aftermarket Tuning. In reality its all three of those factors that make a truck smoke like a freight train.
How do we maximize the performance of these trucks? By using the advantages in electronic tuning, deliver the right amount of fuel for the turbocharger and injector combination in the specific truck, under the right engine load and boost condition. Its as simple and as complicated as that. It starts with custom aftermarket tunes from a trusted tuner to ensure your trucks strategy, performance modifications, and injector / turbo combination are taken into account and your goals (when realistic) are attained. We are going to get into specifics below of what injector and turbo combinations have been proven.
See less See more
Reactions: 3
1 - 20 of 77 Posts
Builds above Electronics Utilizing Stock 135cc/Stock Nozzle Injectors:
Stock Injectors until recently have been considered limited to builds under 450RWHP - That still remains the realistic goal of those drivers not looking to make the change to higher performing injectors. They will however, allow owners who tow heavy (at or near GCWR of their trucks) to do so with little concern for the adverse impact of hotter EGTs and internal temps.
--Supporting Modifications for Stock Injectors--
None, these have already been addressed before considering tuning.
--SCT Race Programming, 135/Stock Injectors, and the Powermax 63.5x88mm
440RWHP - By Dnyo - stock fuel system
--SCT Race Programming, FICM Tuning, 135/Stock Injectors, and the MTW Stage II 64.5x88mm
485RWHP/968Ft-Lbs - by Dyno -stock fuel system (Currently this is the highest numbers I've seen on stock injectors)
--Towing Considerations with Stock Injectors
The only consideration is to have either an appropriate street (under 8-10K load, depending on tune), or designated tow file loaded via the SCT programmer. Depending on aftermarket turbocharger, for example the Durastroke, reverting to stock Ford Programming is also an option. Towing should be avoided with any high performance program, or FICM tuning above 40HP.
Builds Utilizing 155cc/35% or 50% Nozzle Injectors:
155cc Injectors are classified the limit for those who will still use their trucks to tow heavy on a routine basis and are not chasing a higher HP goal. With the right combination of tuning 450RWHP is very achievable. These injectors can produce 500RWHP realistically with supporting modifications.
The stock turbo will still be capable of delivering sufficient air to these injectors, but a better option is to look at a 64x85 class turbo
--Supporting Modifications for 155cc Injector Builds
Regulated fuel return, or complete fuel system depending on power goals.
Cold Air Intake, should you be going after the 500RWHP mark on these injectors.
Transmission issues may develop when pushing 500RWHP, depending on driving habits the 5R110 may not require immediate
attention.
--SCT Programming, FICM Tuning, 155/35 Injectors, and the MTW Stage 2 turbo
**Confident this is the new 500RWHP setup to beat - Awaiting proven numbers**
--Towing Considerations with 155cc Injectors
Concern here lays in towing heavy at altitude, it would be recommended for those who pursue this course and tow heavy to talk with their tune writer to determine how much fuel will be pulled via tuning. The same guidance applies with regard to street and high performance tunes as they do with stock injectors.
Builds Utilizing 175cc/75% - 100% Nozzle Injectors:
175cc Injectors are the moderate point, where a truck is used to tow and work but also hot-rodded a bit more than in previous builds. With the right combination of tuning 500RWHP is very achievable. These injectors can produce 525RWHP realistically with supporting modifications.
The stock turbo will not be able to clean up these injectors completely, and require defueling via programming. The 64x85mm class turbo would be a huge improvement over stock, as these have more than enough in them to spool up a larger turbo, and will benefit greatly by the additional air.
--Supporting Modifications for 175cc Injector Builds
Complete Fuel System to ensure you have 65psi of fuel delivered to these injectors.
Cold Air Intake, at this point the stock Donaldson is going to hold you back getting the required air to these injectors.
Cold Air Intercooler Piping and intake elbow, on the '05+ trucks this plastic piping is known to fail under high boost pressures.
For the transmission, you are getting into that grey area where a Torque Converter will require an upgrade, or even consider a built transmission upgrade.
--SCT Programming, 175cc/100 Injectors, AirDog 2 Fuel System, '03 Turbo, Aftermarket Intake
476RWHP/908Ft-Lbs - By Dnyo - stock '03 turbo
517RWHP/746Ft-Lbs - By Dnyo - Modified '03 turbo
--Towing Considerations with 175cc Injectors
Any heavy towing will need to be done with a custom tow file written to pull fueling out of these injectors. Towing under street files should fall out of normal practice, and no towing under race level files. Towing with these injectors is very dependent on your choice of turbocharger, and will be limited with the stock unit.
Builds Utilizing 190cc/100% Injectors:
190cc Injectors are the stepping stone for those trucks who don't see a lot of towing, and are more of a hot-rod, or off road build. Programming will see builds over 500RWHP, however this will be limited by the stock turbocharger, even with a 64x85mm class charger builds are limited to 530RWHP based solely on a lack of airflow.
A turbocharger is a huge decision point with 190cc Injectors, the stock unit and mild upgraded turbos can't flow enough air to clean these up sufficiently. You will be looking for a 68x94 class turbo to get the most out of these sticks.
--Supporting Modifications for 190cc Injector Builds
Cold Air Intercooler Piping and intake elbow, on the '05+ trucks this plastic pipeing is known to fail under high boost pressures.
For the transmission, consider a built transmission swap.
--SCT Programming, 190/75% Injectors, AirDog 2 Fuel System, Powermax Turbo, Aftermarket Intake, Intake Elbow and Pipe
**Estimated around a 550HP, looking for dyno or track numbers**
Est. 525HP (8000# truck)- Track 13.6 @99 mph - 190/75s, Powermax, no FICM tuning.
Here is a great thread covering full modifications to achieve 600RWHP with 190s and a MTW Stage 3.
http://www.powerstroke.org/forum/6-...cussion/263289-600hp-truck-build-summary.html
--Towing Considerations with 190cc Injectors
Heavy towing will require a well written custom program. Due to the likelihood that you will upgrade your turbocharger as well with these injectors, that airflow will really determine how much towing you can accomplish realistically.
Builds Utilizing 205cc/Any Nozzle Injectors:
205cc Injectors are in reality the limit you can consider without extensive reasearch into a particular turbo/injector/tune combination, still be able to drive the truck daily, have it be reliable, and build it to this level for the average guy. Programming will see builds over 540RWHP, the turbo becomes a required modification at this stage and will determine final power levels.
A turbocharger is a critical point in 205cc Injectors builds, the stock unit and mild upgraded turbos can't flow enough air to clean these up suffenciently. You will be looking for at least 68x94 if not larger class turbo to get the most out of these sticks.
--Supporting Modifications for 205cc Injector Builds
--Towing Considerations with 205cc Injectors
Limited towing should be considered with these Injectors, and will depend on driver habits and turbocharger selection.
See less See more
Reactions: 1
***This space is reserved for updates, further information, and statistical feedback***
For ORG Members: I'm looking for data points and considerations to further the build levels outlined above. All of this has been covered before, via a number of forums and chats I've had with folks. I'd rather this thread not turn into a full fledged debate over one thing or another. Post results, or PM me, and I will adjust these builds accordingly.
Feel Free to post results directly in the thread, its been made a sticky so its easy to find, and will remain a working document.
As we get results in thread, or by PM, I'll get that information up into the front posts accordingly.
:thumb:lots of good info here
nice write up.. Now I know more about injectors then before.
Glad to see this thread is getting some positive feedback.
Again guys, I am still looking for what's worked for these injectors matched to specific turbos - and any modifications required to the tuning to make them work.
Excellent write up, very helpful. I hope I can get some info from somebody on here to lead me in the right direction for a Turbo, cause I have the 190/75 inj. and need some air...bad. Looking forward to seeing what people say
Very nice write up. Just out of curiousness where did you get the dyno numbers for the 175s? Also long ago was it? If its been a few years I think the numbers would improve with new 6.0 stuff out
The numbers may be old and there have definitely been advancements in tuning that would bump those up some but I can tell you that they are conservative, realistic expectations that one could be pretty confident that their truck would be able to attain those power levels. Great write up Ben and thanks :thumb:
Yes, the 175cc number I currently have are older number, before the advent of FICM tuning and the Extreme files on the market now. (Actually, one of those may have been on the stock air filter as well - I'll have to pull out my notes)
The goal here was conservative, realistic power goals. Let the owner think he's building a 475RWHP truck, only to watch it break 500HP is a lot better on the mindset, than building a paper 550+ truck and struggling to get it over that same hump.
I've seen a lot of great info on these builds, and look forward to getting a lot of it all in one place.
Geebus Ben, were you bored tonite? :hehe: That's a whole lot of typing. Thanks for taking the time to do all that. There's lots of good info there that I'm sure will benefit a lot of our members. Nice job. :thumb:
Lots of good info dude! I learned a little more about injectors from reading this. Thanks!
Very nice Benjamin!!!! This thread definitely has some great info that can benefit us all!!:thumb:
That's a lot of coffee...........STICKY!!!!!
I second the sticky!!!
I think I will go ask someone about that.:D
It is a GREAT thread and will get made into a Sticky, BUT there's still some gaps that Ben wants to fill and since there is some chit/chat in this thread, I don't want to have to clean it up twice. :D
Recall that I am the SLACKER... :nod:
I am grateful that so many feel this is another sticky caliber thread.
If I may make a suggestion, lets get it Sticky-ed in here 6.0L Performance Parts Discussion Forum, just like we have my Bullet-Proofing write up stuck in the General 6.0L Forum. This would allow us a working document, in a sense. Where I could continuously update the first three posts the way I did in the Bullet-Proofing thread.
*I'll send a copy of this post to the Powers that be*
Chit chat Shawn? I don't see no dang o chit chat.:look:
:sofa:
See less See more
Done at your request, Ben. :thumb:
1 - 20 of 77 Posts
