John Wood Nut Swinger
It is the oil pump the supplies the engine with lubrication. If your oil pressure is lower than you want then maybe it needs to be replaced. It is not a performance upgrade.
Have one in the new motor... it runs about 25-30 at idle and 50 or so at 2000 RPM's...
It's worth it if you need a new pump. But no point in replacing it if your stock pump is fine. It is not an upgrade just an OEM replacement. That came straigt from Melling.
