1 - 5 of 5 Posts
i just finished swaping in a 17 hpop, it started and ran great for about 15 minutes then it just died. and now it will not start. fuel bowl is full and it reads oil pressure. any thoughts?
Which oil pressure are you reading? Is the HPOP full? The gauge in the dash is the low pressure system. It has nothing to do with the high pressure system.
Connect a scanner and read what your injection pressure is.
what kind of scanner and will it scan with the truck not running?
duct tape & zip ties
Check the HPOP Resevior. I bet it is low. Because you have to bleed out the system. Which means you need oil. Sure when you got it back together you filled it up. But once you ran it that oil was put through the HPOP system now your HPOP is empty. Needs to be filled back up.
You can use an OBDII scanner but it won't give you an injector pressure reading. Especially with the truck not running.
If you are going by the oil pressure gauge on the dash, that is engine oil pressure not the HPOP pressure.
i checked the resevoir and its full, i think i might have an air leak somewhere in the fuel system
1 - 5 of 5 Posts
