1 - 13 of 13 Posts
i have a 05 6.0 it wont start when its cold after it starts and get to operating temp it starts fine but has a pretty noticable stall when i try to accelerate ran a diagostic and got codes for injector circut low on cylinders 1-8, contribution/balance fault on cylinder 4, fuel module control perf I'm thinking its the ficm but not sure has anyone had this problem before
Are ficm volts Good?
i tested it koeo 48v cranking 48v and at idle it dropped to 25v turned it off let it sit overnight now it wont start
information regurgitator
It needs to be repaired.
I used ed @ ficmrepair.com..great service and very fast.
You won't be disappointed
might as well load test your batteries and check your alternators volts.
i had the batteries and alternator tested today both have been replaced in the past three months and are still good i was thinking it was the ficm just wanted any other opinions before i bought that expensive thing
I dont understand how the ficm can cause the no cold starting because after it starts and warms up it will start fine until I let it sit all night and get cold again
The FICM is subject to heatcycling and vibrations from the engine because of its location...and the solder used during the manufacturing process sucks.
The circuit board expands and contracts at a different rate than the solder used, and over time it will develop a microscopic air-gap. When the circuit board expands, the gap is gone (and so are your starting problems), when the board cools..the air gap is there (creating the no-start).
Discussion Starter #13
forgot to post this awile ago but the solder joints had broken in ficm i found a PDF repair procedure by DrQuad that was pretty helpful and fixed it with solder i had in the garage saving some serious money took about an hour to repair i have driven a couple of thousand miles since with no problems :woot:
1 - 13 of 13 Posts
