I just got done changing the fuel filters on my 2010 f250. I cycled the key a few times and everything was fine. Started right up with no problems. After running for a few it died. I cycled the key a few more times letting the pump run thinking it starved for fuel and now the truck will only run for a second then die. You can watch the fuel bowl fill if you lift the filter out. It is now throwing a P2291 code. Any help would be greatly appreciated.
P2291 C Injector Control Pressure Too Low - Engine
Cranking No start ICPis less than 725psi/5mpa. See diagnostic manual - ICPsystem
dont know if it helps but thats the code
Make sure you tightened the filter housings, if they are not tight enough it will suck air and give you the same problems. I would check the filters for tightness and cycle the key 6 times. If you did suck some air it will still be difficult to keep running, but a few tries should clear it out.
