1 - 1 of 1 Posts
I had a problem with my trans not shifting when its in drive. I changed the filter and the fluid. When I drive it, it gets up to 4kish before it shifts into 2nd then about 5k to go into third. If I put in in first then work the shifter up myself it shifts fine until I hit drive then it downshifts to 2nd and revs up to try and hit 3rd again.. I'm not taking it on the main roads to see if it will go higher than 3rd... any suggestions
1 - 1 of 1 Posts
