1 - 11 of 11 Posts
Alright i have a problem. i jumped into my truck to run up to the store. I started her up and went to shift into reverse. The shifter wont go down into reverse. ANY HELP? Trans shows no signs of any problemsa. Its a 2002 F-250 PSD.
duct tape & zip ties
Turn the steering wheel back and forth sometimes the locking mechanism gets stuck. I know this works on my 2002 F-250.
alright i tried that. Did nothing. I shut the truck off while trying to shift into gear. The shifter moved with the key in the lock/accessory position. turned truck back on will not shift into grar. turned it off again and put it in acc and it went through all the gears.
Are you applying the brake. You need to apply the brake in order to shift into gear.
yes i was applying brake pressure. where abouts is the brake switch???
Discussion Starter · #8 ·
alright. What do you guys think could be wrong with it? broken? can it move???
I would check and see if it is working with a volt meter. But like Jon said are your brake lights working.
Discussion Starter · #10 ·
yes the brake lights work fine.
Discussion Starter · #11 ·
well i just went out and started it up and it shifted into gear fine. didnt touch anything dunno what changed from the last time i started it up.
1 - 11 of 11 Posts
