MBRP Performance Exhaust is the number one choice amongst diesel enthusiasts for their high-performance needs! If you’re looking to squeeze everything you can the most out of your vehicle, then these systems are for you! Smoker stack systems are the key to getting that aggressive look which will make you the envy of the road. The exhaust systems and tips that are currently being offered are made of the highest quality materials and feature the meanest look on the street. The mufflers and resonators ensure that you get the perfect sound out of your exhaust, whether you’re looking for a mean rumble or a quieter in-cabin ride.
MBRP Smoker stack systems’ aggressive look is quickly becoming the industry standard. These setups are fabricated in more styles than other manufacturers have to offer. This ensures that your newly improved vehicle is going to look its peerless best. You can feel confident that your one-of-a-kind rig will remain so as it rips up the road with a system designed to get the most out of your truck. These kits are made from the highest quality materials in order to ensure that your truck keeps looking sharp and mean for as long as they do. T409 stainless steel construction and T304 mirror-polished finishes on the xp and pro series respectively make sure that you don’t have to worry about rust, and the black series and installer series are made from high grade aluminized steel. These components even come with warranties guaranteeing their specific strengths: the T304 is even guaranteed never to rust! Sound principles of fabrication and style are behind every component here listed, and your truck is sure to benefit from any of them.
Performance Exhaust Systems and Tips are designed to keep your truck running mean and looking lean, offering the edge in performance and style that diesel aficionados seek. Whether you are looking for a Filter, Cat, or Turbo Back system, you can be sure that you’re going to get lower EGTs, thereby increasing horsepower and gaining torque. The key to any diesel engine is allowing it to breathe in fresh air by expelling hot exhaust quickly. Exhaust tips are going to complete your system’s look with the style you’ve come to expect from this company and their industry leading engineers. They’re available with or without clamps for both weld and no weld applications and because they come in so many different varieties, they are the perfect way to show off your sense of style. If you’re looking for that extra edge in look or performance, these packages are sure to give you what you need.
Mufflers and resonators are an oft under looked component of the diesel exhaust system. Many people install their new exhaust, but are left wondering about what they need to do to get the sound they’re looking for. These mufflers are designed to deliver maximum performance and sound suppression without impairing your truck’s ability to produce an aggressive sound. They are designed in such a way as to be able to replace almost any stock muffler configuration. Resonators are an integral component in a performance system, cancelling certain sound waves that cause an annoying drone inside the vehicle. They even provide a performance benefit by increasing exhaust flow! When you start cutting your truck’s backpressure levels, your motor is going to rumble even more than it already does.
There’s a reason why MBRP Exhaust is the king of aftermarket exhaust systems: they provide the best components in the most styles. Whether you’re obsessed about how your truck looks or just want to get everything you possibly can out of it, these are the parts for you. Smoker stacks are, simply put, the best way to improve your truck’s look and performance simultaneously. These cat back, turbo back, and filter back exhaust systems and their exhaust tips are going to make sure that you are the envy of all as you rumble down the street and put down the performance on the track. Mufflers and resonators help achieve all of this while simultaneously making sure that you can achieve exactly the tone you want.
