1 - 11 of 11 Posts
whats the best way to get more power out of my 7.3 straight piped without a chip? turbo? injectors? or what?
Judging by all the info here, the limiting factor is the Ford PCM. Any particular reason against a tuner?
a truck
do you not want a chip or cant afford one right now? Tuning is how you get the power out of these, youll need a chip if you want to make power
oh i have a chip a crappy edge evo but still want some power that you can feel when you step on it. and chips are a litte rough on an automatic.
a truck
You really need a custom tuned chip, that wont be as hard on the trans as it will tune it. If your adding power without trans tuning its just gonna kill it faster
X2:thumb: If your custom tuned you should be fine on the trans unless you tow in overdrive all the time up in the mountains.
well i am going to get all of the good stuff in it when it goes out and i should re build the motor it has 225XXX on it ya think
PMR = JUNK
225xxx is not time for a rebuild. A friend of mine has 280xxx on his and he put a chip on it.
Get a custom tuned chip. Lots of good people out there to chose from
Matt @ Gearhead Automotive
Bill @ PHP
David @ DI
Johnathan @ Swamps
Aggie @ TSD
TW @ TDP
1 - 11 of 11 Posts
