1 - 5 of 5 Posts
on my 08 when i put it in reverse and also when im going down the road and i hit the brake and i mean everytime it lights up on my dash wiring fault on trailer....and theres no trailer on there... has anybody had this problem or can they help?....its not under warranty
Check the wires at the trailer connector, sounds like something got shorted. If you see any chaffing on the wires or cuts, fix and move to a better location. Does your trailer brake controller lite up like there is a trailer connected?
Message center displaying "Wiring Fault On Trailer":
This may occur due to water intrusion/corrosion in the trailer connector socket or the connector behind the socket. If corrosion is present, replace the socket and harness and lube with silicone dielectric grease. If there are no signs of water, perform normal diagnosis. Broadcast Message 7052, 7108.
good luck
1 - 5 of 5 Posts
