1 - 1 of 1 Posts
This simple process helped me fix my windshield washer fluid so I thought I would post it just in case it might help someone else. My washer fluid didn't work at all...nothing would spray. First I started tracing my fluid lines and quickly hoped I could figure out another way to try to fix this.
So I got my shop vac with the smaller tube that fits into the windshield washer fluid reservoir and vacuumed all the fluid out. Note: If you have a vacuum hose that will fit into the EGR valve hole, that will likely also fit into the fluid reservoir.
Next I used a garden hose with a nozzle attached and used high pressure to spray into and clean the reservoir, and hopefully simultaneously force some fluid through the lines. I then vacuumed out the remaining tap water and replaced it temporarily with distilled water -- just to check it out. It worked great! Perfect.
1 - 1 of 1 Posts
