1 - 8 of 8 Posts
Have one for free but I was currious to know if it fits with no major mods. Not sure what forum to post this in.
I believe it will fit but the bottom will need some minor trimming. I believe the 05 and up grilles are a bit taller than the earlier Super Duty's. I have seen a few around here with the newer grille and it looks really good.
I was thinking the bottom angles were diffrent. Has anyone here done the swap with some first hand knowledge?:dunno:
It will fit just fine. You just have to trim about an inch and a half off the bottom...
when you say "trim" what part of the bottom are you talking about? The part you can see or something behind the grill so it will fit further "in"
The actual bottom of the grill will have to be trimmed...
Not too bad with a dremel and tape...
Just part of the bottom that is it. Just remove your old grille and fit up the new one and see where the conflicts are at. Should only be about an 1.5" off the bottom of the grille. Then tape it off and use a dremel tool and saw off the bottom section...
1 - 8 of 8 Posts
