1 - 12 of 12 Posts
Soo I was thinking if get stage ones but now I'm thinking I should just go for 2's if I'm gonna do it. But could I run them with a 17* from a superduty or do I need to buy an adrenaline or ect...
Guess I'll need a fuel system too eh
Sent from AutoGuide.com App
T500 is a 17* HPOP you need a pump with more volume, that requires either a swash plate change like the Adrenaline or larger pictons like a SRP1.1.
So get your inj's in and check the HPO# and % on the hot tunes, should be 3000psi under 50%..lower % the better.
The way I was explained that the T500 is MORE than a 17*. it is more like a 20*
Well does it have a 20* swash plate or pistons to increase volume..if not it is a 17* pump period...its science one of those mods are required to increase displacement period.
Full A-Team Member
Either way it does the job
You do not need anymore than a T500 to feed stage 2's...
ive been running rosewood stage twos on a stock hpop for 10k now :icon_ford:
Running and maintaining fuel pressure and HPO is different that making the engine run.
Hot tunes will demand more that a 17* will make in and a stock lift pump will also drop the fuel pressure..
Can you run..sure you can run with a worn out 15* and a 40psi fuel but you not going to make what the motor should be able to....just like you can run any Inj's on any turbo, HPOP and fuel system.
A 17* pump will not perform like one that has more displacement...its science either you understand the difference or you buy into marketing hype.
You can also look at the Diesel Site overdrive unit. There are a few different ratios you can get.
1 - 12 of 12 Posts
