1 - 20 of 24 Posts
I have an 05 F-250 4 wheel drive. I dont want to go to high with it because i do use it in refinerys and such to work out of. But the stock 31inch tires just look to small on the body. Can i fit 33inch tires on it without a lift?
Chuck
yeah i had 285-75-16 witch i think are 33's on my truck when it was stock here is a pic
Yes they will
My stock tires on my 20's measure just about 34 inches so you will have no problems.
I'm running 35's and have no rubbing and i'm stock. You will have no problem at all :thumb:
Running 325/65/18's here and no problems...basically a 35/13.50/18.
Rubs just a hair in certain spots, but overall, no probs.
Should be some pics on here if you search under my username.
Thanks.
man no kidding?? that is great to hear!
Yeah I was surprised as well. I was skeptical when I first saw them before they put them on the truck.
Even the guy that ordered them for me said he didn't think they'd fit...haha. :rofl:
But, after putting one on the front and turning the wheels, everything looked good.
They're ProComp Xtreme ATs by the way...don't know if I included that in my earlier post. Great tire, looks good, performs good...been real happy with them.
Good luck!
My other truck is a f250 cc 2wd no lift and I run 285's (33")also. No problem
I too am running 35's No Rubbing!!!
Check out my gallery i have some pics of the wheel wells. It will give you an idea about clearance. My truck is at stock height.
2000 F350 Diesel Crew Cab, Long Bed, 4wd
I run LT 305/70R16 - essentially a 33x12.50x16 tire. No rubbing at all - and I have the older leaf spring front - even less clearance but still clear!
33's on my stock f250 2wd
Could you please post a picture of your tire/wheels on truck, I too am considering that same size.
My camera is in the shop getting fixed/replaced so it may take a bit, but I will get you some pics as soon as I can. They should come from the factory as an option. I am running the stock 17 lariat wheels.
1 - 20 of 24 Posts
