1 - 15 of 15 Posts
is it worth the money? what will it do
Gets rid of surge, adds a very sexy whistle, great cheap mod, Got mine on ebay for 44.00, took about an hour to install it.
i have really good boost numbers now, it wont hurt or help them?
If you are happy with your boost and you dont have the surge like some of us do then it may not be worth your time. I on the other hand, have some surging issues, and I am looking to have the boost earlier, since I have stick, and dont have the advantage of a torque converter working for me.
i kind of just want my turbo to be louder but not mess with my boost
duct tape & zip ties
I didn't see any big difference in boost. It did help my surge I had, and it does add a nice whistle.
I know my turbo O rings are leaking, so while I have to turbo out I might as well. Its a cheap upgrade especially when anytime you talk turbo its at least hundreds of dollars to do anything with them.
WE dynoed before and after the ww at the SSS last year at Trucks Unlimited, and turned the exact same numbers(within 2 tenths). Kept the ww in for awhile(7 months). Put my stocker back on. Pulls harder/longer thru the gears. BUT, if you have surging, then the WW is the way to go.
OK so what I am looking to correct is the surging, but also the fact that it seems to take forever for the boost to come on my 2000 vs when I had my OBS. I would like the boost earlier and just at least maintain it on the top end till I have to shift, since I dont have the auto tranny to maintain a higher rpm through the shifting.
well in your case afblue, you can do the wheel, the banks big head wastegate and the banks quick spool housing. obviously the smaller exhaust housing would allow you to spool up faster the wheel would stop the surge and the big head would allow you to build about another 4-8 psi.
Wouldnt wiring the wastegate closed do the same but for alot less? What I really would like to do if realistic, is be able to see at least 10psi before 2k rpm, like i did on my OBS.
i have the wheel and exhaust houseing....im happy with it seems to spool fast but i never had it with the stock setup so i dont have anything to compare it too.
The wicked wheel i got from Kyle at XDP has taken care of my surge and it sounds freakin awsome!!
1 - 15 of 15 Posts
