2000 F350 Diesel Crew Cab, Long Bed, 4wd
Now that I think about it (here lies my problem - I thought...)
What is the purpose of having multiple levels available. I was just browsing the Quadzilla website - looked at their basic 65hp module - then down the page it said it is adjustable with 3 settings - a 20hp (why :dunno:), a 40 and a 65 hp setting.
My reasoning is better mileage. Then why not go for a 120hp setting only or a 65 for that matter?
I have been told over and over again that the more you tune a diesel for more power - economy is a side-effect. Tune them more and make them more economical. So why not just drive around all day on a top HP setting?
See what happens when I start thinking about something!
Seriously - I'm sure there is some consideration given to limiting high EGT's - but all that asside - assuming egt's are limited - the increase is for mileage whether commutting or towing (or rice burning if thats your thing) - why have multiple settings?
And what benefit will you actually see if you drive 56mph with a 40hp tune over a 65hp tune over a 120hp tune? Does all the different tunes really matter with mileage.
Sorry for the long post - just got to thinking you know!
Addicted to Diesel
I know i want different settings for towing and for playing because too high of a HP tune then too high EGT's towing, and most likely too high boost. other than that i am not sure, plus with custom tunes you can affect the shift points for different tunes also to make the drive and power range better for different options. hope this helps a little. i know i didnt answer all the questions but i honestly dont know what the difference is in HP at the same speed other than more fuel and usually better atomization of the fuel when there is more.
What makes it a good towing tune? Why not run that tune all the time? Or for that matter - why not run a hotter tune all the time?
Why have different tunes? Why not just run a 120hp tune all the time. When you want the power - you got it - when you want the economy - just stay out of it?
Going back to original post - the Quadzilla 65hp box - just a straight 65hp. why have the option of lesser tunes - what good would they do?
I understand if your sled pulling or regurally race ricers - or have a track truck - you might want a hot tune specifically for that purpose - fine.
But what about the standard guy that commutes daily in his PSD that on occasion tows 10,000 pounds on a weekend trip? What about that guy (me) that doesnt need all the different looney, wildman, extreme rocket boosters tunes? What about the guy that just wants really the best mileage he can get with a tune that will meet his occasional tow needs and not suck his tank dry?
A lot of people run high hp tunes daily for that reason, you can play when you want, and if you want better mileage all you have to do is drive normal. The only time your really need to change tunes would be if you are towing something. I am the same way I just run one tune all the time. I change tunes maybe once every 2 months.
Hi,
Most people will find one file that they like and run that file all the time. It could be an economy, tow, street, performance or anything in between tune.
We, for instance, have different settings for different applications.
Our economy is designed for stop and go traffic where it reduces turbo lag.
Our tow of course is for pulling and plows.
Our street is for highway driving and is very economical on long trips.
Our Looney is a city file/show-off file/race file and track file depending on the level of power.
Then we have a street smoke for people who want to play and a transmission only that serves to be used with another programmer at zero power level, for the gauges or to tow very heavy.
As far as which is more economical, that is for you and your truck to decide.
That's the beauty of custom tuning that you can more or less, get what you are looking for with just a tweak :icon_ford:
Thanks,
Vivian
