1 - 20 of 60 Posts
I don't have a boost fooler and i am making 31-32psi of boost when i get my DP chip wont it do the same thing i thought it was all in programing if it doesn't then i will get one :dunno:
Mine wouldthrow a SES light prior to the boost fooler.
With a good tuner you dont need a boost fooler
I have read the boost fooling can be done by tuning. You have to ask for it and it cost a little more. TW and DP both can do it for a fee.
With out tuning out the over boost or fooling the over boost will defuel due to factory preset parameters for safety.
With the tunes i have from Matt at Gearhead Automotive he didnt charge to do this. It is just part of his tunes.
I have a mechanical boost fooler from ITP. seems to me it is worth the 50 bones for peace of mind and I like the fact that it is a mechanical solution.
Can someone hook me up with a link to these boost foolers? Either a write up of a DIY or something i can buy online....Is it true my truck will defuel due to this? and does defueling make you loose lots of power and make the truck stutter?
I get the ABs light when i get on it with my TW tunes...
And can tony make it so i dont need the boost fooler? is there something he can do with his tunes?
W
Guest
you can go to Home Depot and make you own boost fooler for under $20. get the regulator that has a pressure vent for an air compressor. add the 1/4" fittings and adjust it to 17 PSI using an air compressor
You will get a SES light if you over boost and the truck starts to defuel. but it will only last for a short while.
Most good tuners should be able to control the map and make it so it wont defuel with no need of a fooler
Okay well then i think that eliminates the need for a fooler... Im sure tony set it to not need a boost fooler... its just when i put the pedal to the floor in extreme, heavy tow, or street i get ABs and EBRAKE lights on! and not a ton of power, feels like its either missing or hesitating or something
YOu can throw an overboost code with Tony's chip.
it limits the amount of fuel to the motor, ie less power
yeah i dont think im over boosting... on extreme i only hit like 22psi before i got to 60MPH...
Something else is going on with it... im going to clean the contacts right now hopefully that will help
Discussion Starter #20
1 - 20 of 60 Posts
