1 - 9 of 9 Posts
Neither of them come on..
What could it be? Fuse? Blown bulbs? Other?
Matt
duct tape & zip ties
Well why not check the fuses, bulbs, switch, then come back and let us know what you find.
Which fuse is it? Would it be under the dash or underhood?
reverse light switch on the trans?
^Would that be underneath the shift boot?
well the bulbs are fine and the fuses are fine.. wtf else could it be? How do I check the reverse switch on the trans?
TTT where is the trans-switch
Where is the ground I need to check located?
1 - 9 of 9 Posts
