1 - 19 of 19 Posts
I'm trying to find out what it means if I have A LOT of blowby coming from my oil filler cap and my CCV mod vent hose????? What should I do?? I really want to fix this! :doh:
so I also lose compression????
yep your screwed.
not really. piston rings and sleees will prob fix your problem
PMR = JUNK
yep your screwed.
Ha ha, you say that like its a real easy job.
don't scare me like that... sh#t! So thats basically a re-build???
Discussion Starter · #7 ·
yea, no joke....
PMR = JUNK
Pretty much. I'm pretty sure you pretty much gotta tear it down to do that. I don't know for sure though cause ive never done it, but pistons go in from the top, and ya know what that means.
Discussion Starter · #9 ·
.....hmmm......wow.
Discussion Starter · #11 ·
cool. I actually have a thread out under the main "general threads" forum on here that ask how to check the compression and what it should be.
lol, i can see this coming:
Compression check: 220
Dirk: Now its time to worry. :eek:
YEP, been there, done this.
How long has the DIY intake been on it? Mine got dusted by the factory intake and by the time I figured it out and put the DIY on it was too late.
Cost me $4,000 for parts and doing all the work myself.
My compression went from 300 max to 200 min on all 8. I borrowed the tester with the glow plug adapter from a local diesel shop for $20, took about 2 hours to do.
I say drive it till it drops before worrying about the blowby. Mine had plenty of power and ran great, just a little cold natured. Now she fires right up in the cold and don’t puff clouds of smoke anymore.
Only reason I did mine is cause I got a bad load of fuel and messed up the injectors. Before I bought the injectors I decided to do the compression test cause of the blowby I had for the last 3 years. After the test I decided to rebuild the whole thing, engine, injectors, and fuel system.
geez , dont just assume you need a rebuild , like was said , do a compression test , and also, if you can run a crankcase pressure test , before ripping the engine apart, i agree also with, alabamafrog, if it runs ok, dont worry about it
Discussion Starter · #16 ·
could this effect my fuel economy????
Discussion Starter · #17 ·
what does a set of rings, seals, sleeves and all the rest that I may need, cost, if I only need to rebuild the pistons????? Is there a thread that tells how to do a compression test??
powerstroke engines dont have sleeves , and there are alot of things that can cause bad fuel economy , a worn enigne can but its usualy something else with fuel economy issues
Chase....
in-coming call...
Chase
1 - 19 of 19 Posts
