1 - 8 of 8 Posts
I'm looking at a 1996 and a 2000 7.3, and I'm specifically concerned about buying something that is too difficult for me to work on myself. I have a '96 F250 gasser that is a PITA to work on.
Was that a '96 thing? The body style on the 7.3 is different from my gasser, so maybe it's not bad to work on?
Did they fix this for the 2000? Did they make it worse?
I do all of my own work. I do not and will not bring it to "the shop" so I really need something I can work on myself. Thank you.
Administrator
What about the gas truck is so hard for you?
I think diesel anything, especially if you are going with hippie fuel may be out of your league.
It may sound harsh, but in all seriousness if you find a 1996 gasser daunting, then any diesel or anything newer will be much more difficult to work on.
I’m pretty handy and have been wrenching since grade school and I found the 6.7L as my first diesel to have a steep learning curve.
What @GregWork said . Found my 6.0 in an Ex same for learning curve.
Sent from my SM-G973W using Tapatalk
2015 F350 Platinum SRW
7.3 was a dream compared to my 6.7 even post weight reduction so much **** in the way of everything i have never had to use so many different combos of wobbles and extensions don’t know how you torque anything properly but man she’s fun to drive.
oh and i vote for the 2000 hands down!
diesel tech ron rest in peace his vids helped me fix just about everything on my 2002 7.3 300k plus still runs like a dream.
Discussion Starter · #8 ·
Doesn't sound harsh, just sounds like you misunderstand the question. You think there would be some difference between a gasser and a diesel, but I didn't ask about engines. Who gives a **** about the engines? That's the easiest part to work on.
I'm asking which year Fords suck to work on. I have a '96 gasser that is a PITA. You take half the axle off to change the diff fluid (not just a clamshell/cover like a '93 for example), the tranny pan has to come off to change the fluid, the ****ing headlamp is a half-day project, the whole front has to come off.
Engine, schmengine. In buying a 7.3, what should I avoid so I don't have to deal with any more of this ****, or is it just a Ford thing and I need a Dodge?
One thing I found from going from gas to diesel is I needed a bunch of a lot bigger wrenches.
Why? Was everything on the vehicle somehow bigger just because the engine was tougher? Like the shocks and tranny pan and diffs and tie rods? Because my question is not about engines, it's about what year Ford started to suck to work on, or what years suck to work on if it got better after '96 maybe.
Who said it was hard? I said it was a PITA. Or do you like having to take half the axle off to change the diff fluid? Do you like taking the grille off to change the headlight (not the headlamp of course)? There's none of that **** on a '93, none of it on a '97 Dodge. So my question is what Fords avoid that ****.
Why? Do they have less computerized ****? Is it easier to access and replace parts?
I mean... cool and everything but I wasn't asking how to keep an engine running. That's the easiest part to work on.
1953 sounds about right...
If you've got one for sale in good shape, I'm interested.
1 - 8 of 8 Posts
