1 - 7 of 7 Posts
Fixing to do a EGR delete and a 4 inch down pipe. Up dated high pressure oil pump to branch tube fitting. Resealing injectors new down tubes and plugs. Looking for fuel mileage. Have installed the H&S in customer vehicles. How is the SCT?
SCT with custom tunes!!! FTW!!
For the 6.0, a SCT with custom tunes is the best option. Many custom tune writers/tunes to pick from and find what suites your driving habits and needs.
The H&S with canned tunes let you shift on the fly, but that can cause trans issues over time. If you go with the H&S with custom tunes, you lose the shift on fly ability, and currently there is only one person writting custom tunes for the H&S.
Buy the SCT and give Eric a call at innovative diesel let him set you up with a custom tune,and you will never look back!!!!!
SCT SCT SCT.
The H&S I have installed were done with DPF deletes . The customers love them. Four mile to the gallon increase. I want reliability. The EGR valves run coal back through the motor, not to mention the failure rate of EGR coolers. I must have been doing something right over 200k with the original cooler.
6.0's don't have DPF.
Discussion Starter · #7 ·
The DPF deletes were on 6.4 and Dmax. The H&S on those do not require the temp probes to remain.
1 - 7 of 7 Posts
