First, the oil cooler will plug, making the EGR cooler rupture sending coolant into the cylinders, and then popping the head gaskets.What are somethings that go wrong with the 6.0? i heard you want to get the late model 6.0?
but there is always crate motorsI dont know how many years you are talking about here but by the time you get out of school those old 7.3s might be pretty hard to find with less than 250k on them, they are already starting to get harder to f.
Now this is what you are talking about right 6.0L Coolant Bypass maybe i should get my dad to buy this for the 6.0 he got (his dad died this year)First, the oil cooler will plug, making the EGR cooler rupture sending coolant into the cylinders, and then popping the head gaskets.
Remedy: install coolant bypass filter to remove the casting sand and debris from the cooling system that clogs the oil cooler. Dieselsite is where I will be getting mine from
Def a good idea!Now this is what you are talking about right 6.0L Coolant Bypass maybe i should get my dad to buy this for the 6.0 he got (his dad died this year)
