1 - 5 of 5 Posts
The fuel rail plugs would be in the front instead of the rear?
As far as I know the heads are interchangeable
Yep, what he ^^ said. Looks like you have them right since the plugs are in the back, but if you had put them on the other way you could have just swapped the plugs from front to rear.
Edit: or removed them altogether and installed a regulated return.
1 - 5 of 5 Posts
