Hi all, I've been researching (legal) reliability upgrades for my 2012 F250. I'm wondering how critical these upgrades are. Please number them from highest to lowest priority, in your view:
Sources:
dieseliq.com
www.dieselarmy.com
www.drivingline.com
www.drivingline.com
www.motortrend.com
- Water separator fuel filter - get a billet drain valve, or an auxiliary fuel filter (and drain the filter frequently)
- Cold side intercooler pipe (here, here or here)
- CCV re-route/internal catch-can
- High-flow low-temp transmission thermostat
- Upgraded trans cooler
- Metal oil pan
- 2.5" leveling kit and Rancho RS9000XL shocks
- CP4.2 Injector pump disaster prevention kit, or bypass kit
- Or CP4.2 upgrade
- Fuel delivery/separator upgrade
- Engine oil cooler upgrade
- Turbo upgrade, to either 2015+ or aftermarket
- Radiator upgrade (if experiencing low coolant/coolant leaks)
- Glow plugs - how to fix issues?
- EGR cooler - is there a fix for soot build-up, or just replace the cooler?
- NOx sensor failure - is there a fix, or just carry extras?
- EGT sensor failure - is there a fix, or just carry extras?
Sources:
The 5 Most Common Ford 6.7 PowerStroke Diesel Engine Problems
Learn about the Ford Power Stroke 6.7 engine. Is the Powerstroke 6.7L reliable? Common problems and failures on the Ford 6.7 Power Stroke V8.
Heat Is The Enemy: Strictly Diesel's Trans Cooler Has Great Results
Finally, there is a fix for the 17+ Ford Super Duty trucks and their transmission heat issues. Strictly Diesel saves the day on this one. Check it out!
Upgrade Your ’11-’14 6.7L Power Stroke’s Factory Turbocharger Before It Fails
Added horsepower and reliability: replace the turbocharger on your first-generation 6.7L Power Stroke before it’s too late.
Performance Roadblocks of the 6.7L Power Stroke
The 6.7L Power Stroke’s factory injectors can support 700rwhp—but it takes turbo and injection pump upgrades to get there.
6.7L Power Stroke Problems
Common problems with the 6.7L Power Stroke diesel. Ford's first in-house diesel has experienced very few major concerns and a low warranty claim rate, but their have been a few common problems with the latest Power Stroke engine.
www.powerstrokehub.com
Most Common Ford 6.7L Power Stroke Engine Problems
Through the years, we've found that first-gen Ford 6.7L diesels are the most problematic, but issues generally span through the entire run.
