1 - 20 of 23 Posts
Anyone been able to put subs in their ex-cab. I am thinking maybe under the back seat? I'd prefer not to have to do any cutting to make them fit... Any ideas?
Take out the rear seat and build a box to go under it and then take all the hinge hardware off the seat and bolt it into the box. I've seen it before on an 03. 3 10's under the seat and looks factory.
Mtx makes a box to fit under the rear seat with 2 10s. Its a little expensive though. I just took the longer of the rear seats out and replaced it with a custom built box and one 12.
2 JL 10 w1 in a shallow 1.1 Cu. Ft Box behind the rear seat is all you should ever want.
I was skeptical until i bit the bullet, but it hits hard, is clean and the seat remains completely functional.
I run a $110.00 Kenwood KAC-7204 off eBay and it Rocks!
d
Jersey Strokers Director
I made a custom box that fits 3 8's that goes under the rear seat. That way I can stiil use the seats if necessary.
I used 3/4" plwood, if you used 1/2" MDF, you should be able to squeeze in 10's using the same outside dimensions as the one I made.
I have a crew cab and removed the center console completely. I have 2-Earthquake SWS 12's firing to the floor. People hear me coming from a distant. The box is maybe 1/2" higher than the center console. Yes I lost some storage and a few cup holders..........but I love the way it sounds!!!!
hey man. maybe i missed it, but what are the dimensions on ur box? i have an ex cab dually ive been wantin to put something in, but just dont look like much room. ur setup looks pretty clean and id like to do something like that.
Discussion Starter #15
Aronda- that looks great! Wow yeah I'm definitely going to have to measure out and do something like that. Nice job though!
Bump for u guys. I had my 2 ten rockford fosgate speakers in my 03 extended cab, but it stuck way out past the rear seat. I also put blocks underneath the bench to raise it up
pics pics pics
I don't think I ever posted exact measurements. I think it's 9 1/2" front to back, and about 5"-5/1/2" tall. That way w/ the 3/4" ply I used, the 8's fit in and I didn't have to raise the back seats and it barely sticks past the front of the seat, leaving room for your feet.
1 - 20 of 23 Posts
