Certified Pre Ownedcpo? what might that mean?
Got 94K out of front pads and roters and 108K on rear pads. Truck is 08 F350 DRW.Just wondering how many miles people are getting out of their brake pads. I've got 52K on mine.
On my '97 I only got 60K out of the fronts but, 90K out of the rears.
Well anytime you replace the pads the rotors need to at least be machined if not replaced. If not the new pads will wear into the existing grooves and they wear a lot faster. So I'd just measure the thickness of the rotor and find what the minimum thickness number is on the rotor and do the math, I think you'd be fine turning the rotors with we arn't warpedI have 63k on my 08 and the dealer says that at the next oil change (66k)that I'll need new pads. Did you guys change rotors as well when you changed pads or do you expect the rotors to have enough material for another 60k+ miles?
