1 - 5 of 5 Posts
Sure just order open ended hub covers for the front when you get them. Or run with no hub covers at all.
Any where I could find how those two options look also where I could find specs on wheels as far as load ratings
You can also drill the 3 1/4 hole (I think) in the center of the cap. I did that on my ultras and looks great.:thumb:
Supporting Vendor
Tire & Wheel Specialists
Correct!
I'll see if I can scrounge up a photo with the open hub cap option. Also as far as load ranges; If you put your vehicle into our fitment guide and search for wheels available for your vehicle, it will filter and only show you products that are rated for your vehicle. The MB72's (pictured above) is probably one of our strongest wheels.
MB72
Load Capacities:
14 Inch trailer 1900 lbs
15 Inch 5 hole trailer 2150 lbs
15 Inch 6 hole trailer 2830 lbs
16 Inch 6 hole trailer 3200 lbs
16 Inch 8 hole trailer 3960 lbs
15 Inch 5/6 lug truck 2200 lbs
16 Inch 8 lug truck 3415 lbs
17 Inch 5/6 lug truck 2200 lbs
17 Inch 8 lug truck 3415 lbs
18 Inch 5/6 lug truck 2200 lbs
18 Inch 8 lug truck 3415 lbs
20 Inch 5/6 lug truck 2200 lbs
20 Inch 8 lug truck 3415 lbs
1 - 5 of 5 Posts
