will a set of factory 2007 20" wheels fit on a 2004?? there is a guy with a set of Harley Rims for sale mint... just want to know if they will go on??:dunno:
They will bolt on, but the backspacing is 1-1/2" more than the 99-04's use. This means the wheels will be 1-1/2" closer to your leaf springs and will rub when you make hard turns. They will also look funny sitting in so far.
You can buy spacers to put them where they are supposed to be but you lose some strength whenever you use spacers.
really?? so you would need spacers in all 4 corners?? is that expensive?? or is it more harmful than good in the long run?
