If a tire goes on a 10" wide wheel would the tire be wider than if it was on an 8" wide wheel assuming its the same tire?
yeah i believe it sets the tire wider and a little shorter in how tall it is.. but not positive
The tire would not be any wider on a 10" wheel than on an 8" wide wheel. You still have the same amount of surface area touching the ground. The tire just looks more Bulbous with the 10" wheel. I would not run a 10" wheel unless I was running a tire that was 14+ inches wide.
