1 - 11 of 11 Posts
it just did this on Monday after a two hour trip up north. When i got off on th exit ramp i noticed a HUGE cloud of white smoke every time i let off the gas, then it struggles to get going again then when it does it works just fine no smoke or anything till i let off the gas. its not the egr valve ive had that go out many of times before this was like five times more white smoke then that. as you notice it smokes in the vid but yesterday when it happened there was alot more smoke then that, in the vid i started it after it sat for a day. i watched the gauges it didn't over heat or anything and the only code that came up was po263 [cylinder 1 contribution/balance] no idea what that means how bout you guys ?:confused::confused::dunno::dunno: i was thinking erg cooler or/and head
gaskets
my guess is an injector. mine had the same/similar problem.
Wow. I'm a little dizzy now... On edit: I would guess injector #1 is bad. I just realized that you got a code for that inj.
:bump::bump::bump:
Injector failure.....
Discussion Starter · #7 ·
maybe the injector but why only at idle, works when up to speed?
possible just more pressure when up to speed??
good luck, hopefully an eeasy one to fix!!!
my vote is injector, sounds like it's running on 7 cylinders when you rev it up in the end. What did the white smoke smell like?? good luck dude!
Discussion Starter · #10 ·
bump to the top
Discussion Starter · #11 ·
its def antifreeze pissing out the exhaust going to shop today but probably wont get looked at till after the weekend (hopefully i can get some head studs done)
1 - 11 of 11 Posts
