The OEM vacuum lines ran from a push on barb fitting right on the hub up to the frame rail attached to the brake line and the ABS line. Each hub would have three different lines running out there.
Up under the hood behind the p-side battery is the vacuum pump, the reservoir, and the control solenoids. Unplug the electrical supply to the vacuum pump and see what happens.
