New here and this is my first post.:dunno:
Need help with my 2006 6.0 turbo delima. The ford Garage (under Warranty at 30K) put a "Remanufactured" turbo on without telling me. Now I'm at 130K and need to either rebuild the turbo or get another one. Rumor is it's risky rebuilding a remanufactured turbo (my mechanic told me) but not impossible. A stock rebuild kit may not work if the opened the bearing housing bores and installed larger OD bearings...so if I just replace the turbo...which one (cost effectively) should i put on? (just fyi...turbolag was bad before and I'd like to get rid of all i can through this)
use of truck: Primarily short trips (30 mi.) (empty) and towing a 34 ft fifth wheel (6-8k lbs) cross country.
6.0, ARP Head studs, 4" sst turbo back, IRP Remote Oil Cooler, AFE intake, EGR Del, Blue Spring, SCT Tuner.
