1 - 2 of 2 Posts
I condemned a HPFP due to brass debris found at the fuel cooler valve and at every feed tube. I replaced and cleaned everything...
REPLACED
HPFP
HFCM
BOTH RAILS
8 INJECTORS
FUEL COOLER
FILTERS
FEED LINES
CLEANED
TANK
SENDING UNIT
RETURN and FEED LINES
I bled the system which took forever. Finally got it going. Within minutes after clearing adaptive tables. all my SFTs were bad. from -5 to +11.
I took a sample at the fuel cooler valve and sure enough, that same brass debris... What did I miss???
any updates
1 - 2 of 2 Posts
