1 - 20 of 56 Posts
if thats what i think it is then your introuble......like $400 trouble.....
dude im just kiddin.......that looks like your blower fan.........if its the box i think it is........i cant tell im tired and didnt look at it hard.....
is that the fuel pump shut off deal if ur like n a wreck ?
This thing is driving me nuts - it makes noise (ticking/popping) when the key is turned on and/or the truck is running!!! ac blower motor? I can't tell that something isn't working? :confused: It's up under the passenger side floor board where the carpet ends......
im confused by that????? under so its on the bottom of the truck then?????? if so its not your fan......if its in the cab under the dash passenger side then its your fan......turn the knob to the off position haha...........
your vid says its private so i cant view it......
if it is only when the A/C is on, then its the blower motor....mine started that crap yesterday
it does it regardless if the ac/engine is on or off........vid should work now
Vid works and hear the clicking. How many miles on the truck?
PMR = JUNK
Open your hood and listen near the passenger side fender well. It may be the vacuum pump. There is no sound on your video so im just guessin.
Juding from the vid its an 08 guys. Should be under warranty
PMR = JUNK
:doh: Didn't see that. Do 08's have a vac pump?
Discussion Starter #13
its under warranty - its whatever that thing is, i can feel it when it clicks/pops
its a blend door motor/actuator, an electric motor to move either a temp or position door on your a/c heating system, and the blower motor is under the hood on the passenger side of eng comp. not under the dash, my blower wheel broke at 9k, no problems since. To see which it may be see if you can change positions of the outlets, dash floor or defrost, or hot to cold, recirculate(max a/c) or outside.
Definately sounds like a relay clicking, looking at the movie, it looks like there is a relay right behind those wires, no idea what it would be for... try pulling it, (if it is a relay) and pop a new one in there
Some kind of relay switch turning on and off/malfuntioning?
Mine does the same crap................
Its just a clicking reminder that the 7.3's are better....
1 - 20 of 56 Posts
