Hey guys just picked up a 4" lift for cheap and just got to b.s with the guy and asked if he knew anyone with a set of 20" wheels well come find out he had a set off 22" Zora zr10 wheels all said and done I walked out with a lift and wheels for CHEAP. Now I was wanting 20" but for the price couldn't pass up . What size tires is everyone running on there 22" that will clear with a 4" lift and still look good pics would be awesome thanks :ford:
I have a 4" lift on my 350 4x4 (4" front 1" rear). I was running 20" rims with 35"x13.5" mud tires, these rubbed on the drivers side wheel well (rear side of front well). When they were about shot, I replaced them with 35"x12.5"A/Ts on the same 20" rims. The 22" rims should give you the same results if you stick with a tire that is 35" high and 12.5 wide... height is height, the rim is just the hole in the center.
Hope this helps.
Those are my 37/12.5/20's....rub w/ a 6" lift when I turn hard and hit a bump...
