I am looking to replace all of my injectors, and am currently looking at Warren's. I know I will get the premium spool valves, but not sure what size injectors. The truck is stock besides a turbo back exhaust and Blessed Performance's Ecobeast Street Tune. Should I just stick with stock size injectors or go to the 155's(with stock or 30% nozzle?)?
Mr. Crossthread
If you're staying stock turbo I'd go 155/30 or 175/0.
Sent from my SM-G991U using Tapatalk
06 6.0 drw 635 rwhp (retired) 08 KR build in progress
On stock turbo the smaller ones are sufficient. I had the larger ones on my old truck and it took a bit of ficm tuning on my end via HP tuners to get it where I was happy with performance and smoke levels which were almost nonexistent when I was done tuning. Dyno results spoke for themselves.
If you're remaining stock and have no plans of upgrading turbo size, then just stay stock or take waggonerj's advice.
Anything above stock parameters (or 175's +), WDI recommends custom tunes to make them work/idle correctly and a RR for warranty reasons.
Good luck
Reactions: SledHead24
