1 - 14 of 14 Posts
I am fixing to install my gauges just wondering what order you all like to have them starting from the top of the pillar down. I have Three gauges Boost, EGT, Trans temp.
Pyro on top, then boost, and tranny temp on the bottom.
-French
I put mine in order to how fast/critical the reads are to me, Pyro on top, want to get out of pedal in a hurry if it gets too hot, boost center, let out a little if the truck tries to overboost. trans bottom, just want to ref it every once in a while when pulling a heavy load or getting on it a few times.
Pyro on top, boost, then trans temp
i seem to be opposite of everyone so far ... i like my pyro on the bottom, seems to be easier to look at to me... but i have . . . .
Boost
Fuel Pressure
Trans
Pyro
Pyro, Boost, trans temp.
I put my boost on top egt in the middle and trans on bottom. The egt gauge is closer to direct eyesight in the middle for me
air pressure
boost
tans
pyro
From Top to Bottom -- Trans Temp, Pyro, Boost, Coolant Temp.
Fuel Pressure is on the steering wheel pod.
Trans
Boost
Pyro
1 - 14 of 14 Posts
