1 - 20 of 33 Posts
there is a toggle switch on dash that has green wire that goes to the green plug in pic...it has on and off..what does this do? Thanks previous owner had no clue..said guy before him did it and forgot to tell him what it was...
it is a 01 7.3 ext cab with auto..
Thanks!!
What sensor is that above it? Does it do anything when you flip it? Mystery switches are always interesting
It goes to the Wastgate Solenoid. It is the dump line for the pressure to be spent back into the intake.
Wtf?
It kinda sorta looks like an intake heater or crank case heater. Looks like it heats up the incoming air charge. Is it a cold-weather truck from 2 owners ago? Where are you from and the previous owner from?
There's not a hose going to it is there?
Sent from my DROID BIONIC against my will
Its gotta be some aftermarket job. See the red butt connector with the black wire (that is almost falling out)?
The newer 7.3s came with them cause they had bigger turbos
meth injection?
Discussion Starter · #10 ·
its not meth injection...i really have no clue...it doesnt seem to do anything with it on or off... but yes the butt connector IS the wire im talking about..and its fed into the green plug?...what does the green plug do...does anyone have one like this?
I literally just said what it was above, it has two wires to that plug to activate the solenoid, one power and one ground, the other two are for the wastegate
Those other two lines go to the turbo and intake
Why would there be a manually controlled wastegate? I've never seen that before. Pull the boot and look in there
No offense, but you've been spewing a lot of bullsh*t on this forum since you've started posting.
First of all, a WASTEGATE has nothing to do with a regulated air return, IE divertor valve, which is what you are insinuating. A wastegate hooks up to the turbo; a divertor valve, which these trucks are not built to utilize, does a regulated return like you are saying.
Second of all, human interaction isn't needed for a divertor valve OR a wastgate. Why would you put a switch on a wastegate? Do you know how to control a turbo better than the turbo does?
Do you see a "manual wastegate controller" on this stock super duty? No. Because it's on the turbo.
Exactly. This guys been saying some crazy **** since he's joined. No offense to him.
You wont see a wastegate to control on a 6.0
Sent from my SPH-D710 using AutoGuide.Com Free App
The only thing the green wire might be is an ebpv controller. where does the wire its spliced into go?
Right because it's a vgt.
Why would an ebpv wiring be on the intake charge piping?
You obviously haven't messed with newer 7.3s. And who made you the expert to call others opinions bullsh!t?
That solenoid receives pressure from the Y then goes to the wastegate. So my guess is the switch would turn off the solenoid not allowing pressure to the wastegate so it won't open allowing more boost. It'd work like disconnecting the red vacuum line to the wastegate
Why would you make a switch that would keep the waste gate closed? So you can blow the turbo?
I'm calling that guys bull**** because I've seen him post a few posts now which made zero sense and were totally inaccurate.
It wont blow the turbo. Like I said, it would act just like unplugging the red vacuum line which many people on this forum do.
Idk what you're referring to talkin about 450hp on stock turbo?
And just saying, the OP asked for opinions, the guy gave his opinion, not your place to say he's full of it or not.
1 - 20 of 33 Posts
