1 - 5 of 5 Posts
I have a 1999 F350 super duty 7.3L built in July 1998 (therefore called a 99, not a 99.5)
I need to replace the water pump along with the gasket,etc.
The ford garage says the P.N. is FOPW-455 for the pump, FORT-1201 for the gasket and FORG-602 for another gasket.
Ford 7.3L Powerstroke Diesel New OEM Water Pump F81Z8501FA
says the following:
99.5-2003 Ford 7.3L Powerstroke Diesel New OEM Water Pump from Ford Motor Company
[F81Z8501FA] $289.99
99-03 Ford 7.3L Powerstroke Diesel Water Pump
[MSF81Z8501FA] $269.00
I can find [F81Z8501FA] on internet, but not [MSF81Z8501FA] which would apply to my early 99 truck. Anybody can help?
TIA
Wow, you can probably just get the part from any parts dealer like Advance or Autozone, they will look nit up by VIN.
BANNED by Kris
They are the same part numbers. The "MS" was added to the PN so that if you tried to search for a cheaper one you would always come back to PDP's website. Read the part number this way:
F= '90's vehicle
8= 199->8<- first year of use
1= International
Z= Ford Service Part
8501= water pump (anything between 8500-8600 denotes water pump)
FA= Design level. First design used would be a AA. The upgrade would be a BA, then a CA, and so on. The FA code supersedes the AA design so in actuality you should always be able to put a FA part on a AA motor but not the other way around.
Using Motorcraft numbers opens a whole new can of worms. Amazon sell a Gates 45000 water pump for your truck for $85. Search Amazon for my '97 water pump and it is the same thing BUT has a removable neck. Same part different revisions.
Clear as Mud? Cool.
Discussion Starter · #4 · (Edited)
Mud as clear... or the other way around. Thank a whole lot! Would you believe 514$ in my home town in Québec, Canada! But the hourly rate is much cheaper.
BANNED by Kris
1 - 5 of 5 Posts
