hpop
Alabamafrog is basically right. The high pressure pump takes base oil pressure, thats at about 50 psi and raises it to between 500 to 3500 psi to run the injectors. the high pressure oil is basically used to help open the injectors instead of high pressure fuel. power stroke fuel pressure runs about 55 psi.:icon_ford:
