1 - 18 of 18 Posts
My truck 04 fx4 has now turned 75K and I want to change all the fluids I don't know what viscositys and quantities to use in the tcase, tranny, front & rear diffs and also what makes do you recommend?
I recommend mobil1 for the diff fluids. 75-w90 front 75w-145 rear. Valvoline is good for mercon V.
Use mercon V for the Transfercase.
Mercon SP or LV for the transmission.
Mercon V for the power steering.
Dot 3 or 4 for the Brake fulid. I use DOT 4.
I and many get filters from here. I buy the bulk discount and sell the extras for my 2 next door neighbors that have 6.0's
www.dieselfiltersonline.com
When have you changed the
trans fluid, external filter, and internal filter?
the air filter?
Powersteering fluid?
Brake fluid?
Thanks for that haven't done any up untill now all it has had done to date is EO and filters evry 10k and fuel filters every 15k
that seems a bit long on the EO. 6.0's are sensitive you might cut those intervals down a bit.
For standard engine oil, go between 5,000 to 6,000 miles. Syn go 6,000 to 7,000. syn with a bypass I have gone up to 9,500 miles, that was my last oil change. this one I will be going 11,000 miles. I test the oil and I keep getting good results.
Transmission is 30,000 miles depending on how you change the fluid, then i will be shorter.
I haven't seen any problems going 10k on sythentic oil but I guess we will see when my next sample comes back.
The last time I had my standard oil tested (Blackstone), they recommended that I push it out to 9k miles ... I have not been brave enough to let it go that long though.
I will probably switch over to a synthetic on the next change.
I used amsoil in all of my fluids. You can go to there website and it will tell you what to use and how much it holds as well i like amsoil product but that is my .2 cents
Discussion Starter #11
Thanks guys I realy do aperciate the input.
I think on the next EO I will pull a sample at 5k and see what that says and go from there. I don't know if it's comeing form Europe or not but I have a realy hard time buying in the h 3k oil change interval. Maybe it's becuew I'm usto Changeing oil anywhere between 15- 25k
Discussion Starter #12
Just picked up a blue spring from international on the way home :) still trying to find someone that sells mercon lv around here. Looks like it might be a trip to the stealership
Discussion Starter #14
Thanks, the only thing that I could find that was lv compable was valvoline, i got mobil 1 dif oils and tcase oil and t6 5w40 EO
picked up $350 worth of oil good job she don't need this all the time!
Discussion Starter #17
So tonight I got the EO, tcase and trans done I haven't flushed it I just draind 8qts then I am going to drain again change the filters and fill back up again then run it for 1000miles pull another sample just out of intrest and compare it to the one I have just taken to see how much doing it this was cleans up.
But just as you get frustrated is nice to look up and find inspararion :D
amsoil?
i really like amsoil never used it in a diesel. mobil 1 is good i was wondering if u guys ever done royal purple all the way through the drivetrain and motor. i have done that oil change through four wheelers and bikes but not really a crew cab dually diesel lol.:taze:
1 - 18 of 18 Posts
