Happy 2018, and the last OBS turned 20 last year.. Now we're all ancient and off the smog radar!
i installed a S&B filter but the box is too big, intercooler pipes hit, squeezed between AC line......up against powersteering line.
no issues w/6637....but wanted cold air f/summer...
KCTP38R installed and doubled my boost numbers, still 2-300°F drop across the turbo
summer EGT will be interesting to see pulling up the grade.
lot's of messing around with intake to get it plumbed in an acceptable manner...the larger intake plays with fitment. easy 30psi plus on boost numbers.
btw A size 140 oring or a oil filter oring from a suitable size will work on the turbo inlet, the OEM SEAL DONT WORK W/KCTP38R..they are sending orings now I believe with each unit.
new rear wheel bearings, rear differential with new OUO cover.75w motorcraft/modifier took 3.374 total fluid ounces...
I purchased my first 5 gallon pail of OPTILUBE XPD...man doth that stuff stank or what?!!!
also first 64oz of NMF fluids to try, i like the science behind it. made a bunch of videos if anyone is bored....
Still bucking on down these ****ty california roads......even on straight roads you hold a slight left hand turn pressure to keep the road-crown (rain shedding round) from sending you off right....
pending a SD valve cover gasket/UVCH/harness upgrade, got the parts tho waiting to see how winter goes w/cold starts and if anything gets melty, not gonna repair OEM OBS just will upgrade....
Oil cooler was also just replaced as I didn't do it when i had engine pulled.....lol i got to the right side manifold/oil cooler and called it good as i had changed orings in 2010....but now she's new w/POR-15
Odometer will turn 150k on next rip...hip hip horay!!!!!
Love My Truck!
Love My Truck!
