62961 - 62970 of 62970 Posts
Well this started last Saturday Lots of TLC [money] just hopes it makes at least another 10 years with no significant problems
New rockers and cab corners to make it look good-Sent to a friends body shop
New KDD heads, Arp studs, ODAWG intake, KC2 turbo,WDI injectors 195/30, torque converter and billet input shaft, Ford oil cooler, FASS & DRIVEN DIESEL fuel system.
I cant leave stock alone and hope I not making a very expensive mistake
Now I will just need to make sure brain is engaged while driving it
Time will tell but it should be good for many more miles
So you say a buddies shop, what does cab corners/ rockers cost to replace, can you ask ur friend for a ballpark if you arent paying retail? Just curious what that job would cost on a regular day?
5 days ago I installed the repaired FICM from BPD and I figured I might as well change out my FICM relay as it's probably the original. My Genuine OEM Ford Part #: F8OZ-14N089-AA arrived today. While comparing the two, I saw what I'm guessing is the date of manufacture; old one says 06125 and new one says 19212 - probably the year and the day of the year. Am I right?
He said normally about 3000-3500 for inner and outer rockers and cab corners. He likes to use the replacement inner rockers and extended cab corners but has another guy bend one piece outer rockers out of a litter thicker material. Less seams and welding needed so should last longer.
Had the 05 excursion in for the head gaskets and they said motor was in really good shape. only 123 k on it. Also had bigger injector put in as a couple were bad.
17 year old Numb nutzs (mini me) went into mud last night knowing the 4x4 doesn't work. It shut down and would not start and that's how they left it at last night. Started this morning and he almost got it out, died and would not start again. Pulled it out with my 6.7 (ridgrapplers griped flawlessly). Gave it a shot of ether started and headed home. Died twice on the way home when he stopped at red lights. Little ether both times and maid it home. Kids need to learn how to 4x4 correctly, work on and maintain their (my) truck. Looks like ipr with forscan but I'm going to check a few more things.
Completed headgasket job on my 07! No better feeling than watchin that ICP hit 500psi and hear her roar to life. O-ringed heads with OEM gaskets. Re-sealed high pressure system. Original injectors still strong at 185,000km, top oring was rock hard and brittle. O-ring kits for them good as new. Original STC fitting on pump replaced. Found broken standpipe upon disassembly also. IPR % much lower now lol.
Whats the ipr reading when idling warm ?
When i resealed my system i was at 23.4 %
Sent from my LG-US996 using Tapatalk
Nothing exciting really, new Motorcraft oil filter and fresh Delo 5W40 synthetic. Noticed a little oil residue around one of the hot side CAC hoses so I repositioned/re-torqued it.
Jahcure04, oil temp 194 F and IPR command 23% at idle.
