3761 - 3776 of 3776 Posts
· Compression Ignition Addict
Took a "blind stab" at a couple of products:
Bought a 3M Medium Duty Headlight Restoration Kit for one headlight (needed sanding) and some Meguiars Headlight Coating for the other (no sanding required on this headlight - was still very clear).
Finished product looks pretty good. Supposed to last 1 year. We will see.
Found Scotty after-the-fact .....
· Premium Member
Direct replacement to LED bulbs - these are great! I just put them in and they didn't even need re-aiming - I didn't expect that. Amazon purchase.
SEALIGHT H13 9008 LED Bulbs 14000LM Dual Hi/Lo Bulbs with 400% Brightness Cool White Plug and Play, Quick Installation Halogen Replacement, Pack of 2
4 small screws (7/36" socket) for the housings. The same for the top of the grill as the assembly will catch when trying to remove it. You will probably have to loosen the 4 bumper bolts (18mm) to get to the lower screws. Complete plug and play! Total time about 15 minutes.
· Registered
Pictures or it didn't happen
Sent from my SM-S901W using Tapatalk
· Premium Member
Atmosphere Water Automotive lighting Sky Street light
Automotive tire Asphalt Tints and shades Freezing Landscape
· Registered
Just ordered a Mishimoto coolant bypass filter kit and looking to pick up an oil bypass filter kit as well, but don't want to support Sinister so trying to decide what brand/kit to go with and if engine doesn't already have blue spring kit I'll be ordering that as well.
Current Airdog lift pump is crazy loud so I'm ordering the newer 5g .model right away
· Registered
Bought a tuning package from Gearhead yesterday, uploading them this afternoon. Unlimited tow, 8K tow, and SRL+ (my heads are studded). Stacking the PCM tuning on top of the Atlas40 FICM tune I already have.
I have the same set up but no studs. Pulls a 7K TT nicely with the 8K Tune and the SLR+ is screamer compared to stock. I leave it in 8K Tow to stay out of trouble.
· Registered
2007 F-250 King Ranch
Back at it again. New Fox 2.0 steering stabilizer and the aluminum wire loom from Blessed Performance on order. Have a new 4wd actuator and windshield washer reservoir motor that I've been putting off installing.
· Registered
Wheel bearing hub for front driver side, already changed passenger side ‐ it had play in it. Driver side is next, had to work last.night so not in the mood to work on truck this weekend. Nice jib for next weekend.
Sent from my SM-S911W using Tapatalk
Reactions: bismic
· Registered
I seriously need to keep off the Ford Parts website. Ordered new engine cowl pieces as mine are cracked and worn ( both left and right sides), new push pins for them, new retaining clips for the dash around the instrument cluster since i exploded like 4 of them when i was last checking the instrument cluster wiring, and a new radiator shroud emblem (mine is just worn looking). Just trying to clean her up and get her looking close to new again. Add this to the list of better than a half dozen things I have sitting around that need to get installed on the next nice weekend that I'm not busy. Also gonna prep and repaint the windshield wiper arms while I have them off.
