08 style mirrors with power fold option. Just waiting on shipping - things take forever to cross the border into Canada.
Sent from my SM-G973W using Tapatalk
If you don't mind, I'd love to know your thoughts on them when you get them. The ones I picked up off Amazon, one mirror works perfect, and the other vibrates badly. I've heard nothing but good things from those Trail Ridges, and I want the power fold option as well08 style mirrors with power fold option. Just waiting on shipping - things take forever to cross the border into Canada.![]()
@TwinExcursions, @Doward
I bought and received a set of PF mirrors from @1AAuto.com. They are the Trail Ridge. I mounted them and the plug is a direct fit for the power options (up, down, marker and heat) which is nice. The power fold is a different story. It has a wire kit with a switch that is provided. However, there are absolutely NO direction on how to wire this (at least in mine). But here's the kicker. You have to pass wires from the cab to the doors.
On my 07, The boot that goes in between the door and the cab is not standard. There is a plug that goes from the door and hooks to the cab portion. The plug is just like the one we have for the ECM, in that there's a lever that one flips down to "unlock" it and remove the plug. Now for the life of me I have not been able to figure out how to pass the wires from the cab to the doors.
I am trying to use the more factory install (following @Dante04SRT instructions), with the factory window switch. But as of right now my power fold is not hooked up and unless a miracle happens it's not going to.
If anyone has done this on the '07 please chime in and let me know how you got the wires from the cab to the doors.
The mirrors are awesome! I LOVE the added visibility and the blind spot mirror is incredible. The field of view for the blind spot is increase ten fold and nearly eliminates any guesses. You'll love them![/quote @zsargent
Don't know a good solution for adding a wire loom from door to cab. That has to be extremely frustrating for you.
Can you tap off of power feed for mirror select switch (driver/passenger) to feed the fold switches? Would require having to mount switches on door panel. Give me some time I'll pull up wiring diagram for my 05 and mark it up to show a possible solution using existing wiring (also will rely on wiring being same/similar between model years). Only thing is I don't know rating of switch to select mirror and if it will handle current load of fold motors. Could be a possible solution.
Thanks for feedback that the mirrors are good quality and better fields of view.
@zsargent@TwinExcursions
I am using the factory 08 window switch (L, R, Up and down) with the PF option and it works well. Just the PF isn't hooked up yet. I replaced the 7 wire plug that goes into it with the factory 8 wire one. The extra wire is for the PF.
The new mirrors have the factory plug for all functions except PF. They added another plug which has a light blue wire and a yellow wire. That's for each mirror.
I have the power folding replay that is included in Dante's write up but not sure where that goes really. My bad for not doing a bit more homework on this but there has to be a way!
Early ChristmasShipped off instrument cluster to be fixed
Trail Ridge 08 style mirrors w/ paint match
Cab mounts
Drive shaft halves
Carrier bearing
Ujoints
Yokes
led reverse bulbs
Every other month is early Christmas with this truck lol. Love her thoughEarly Christmas
If anyone else is interested in being a perferred Amsoil customer, just let me know via email and can call you at another time to get you set up. Just thought I'd throw it out there. [email protected]Switching from T6 + Archoil to now just Amsoil Signature 15W40. Ordered it yesterday. It's a little more pricey but not by much. I was getting T6 2.5 gal for about $50 and 1 gal for about $20. Then the Archoil was another $40. So total for that was around $110. I got the Amsoil 2.5 gal for $85 and the 1 gal for $35. Total for the Amsoil is $120. I decided to use the preferred customer program since I plan to continue with the oil they have for my other stuff and by being a member, you get pretty good discounts and free shipping on orders over $100 so to me it's worth it. I will let you guys know my impressions after the oil change.
Also, I have my LED's in for my gauges. Just have to get them installed. Haven't forgot about that, time has not been on my side. Especially now that it gets dark not long after I get home.
Is there a minimum order, Corey?If anyone else is interested in being a perferred Amsoil customer, just let me know via email and can call you at another time to get you set up. Just thought I'd throw it out there. [email protected]
Nope, its just a $20yr membership fee, but just for a single oil change with filter you will save way more than that having the membership.Is there a minimum order, Corey?
Well heck man, not sure if I would have saved anything buy going through you instead, but will keep that in mindNope, its just a $20yr membership fee, but just for a single oil change with filter you will save way more than that having the membership.
