ok so when I pulled out my engine, my cherry picker wasn't high enough, so I had to improvise. Well I got it out, but managed to crack a box in the mean time. My question is, what is it and should I replace it? Thanks!
And my improvision...:rofl:
I think that is your A/C evaporator :eek:hnoes:
Heater box. Just seal up the crack.
Are you sure it's the heater box? The heater hose goes into the firewall. Is the firewall just a solid junction? Thanks!
The AC evaporator is in there. You should just be able to seal it up, unless you broke the evaporator.
as long as you didn't break the evaporator you should be able to just seal it up with some epoxy or similar as stated above :thumb:
