1 - 12 of 12 Posts
Lots of good post and replies, but none found as of yet for my problem. I have a 2004 F350 6.0L work truck that has been getting worse over the past year or so with fluttering under power. It sounds the same as when you let off the throttle after pulling hard, but in this case it's while you are pulling hard. I thought it might be something with the VGT acting up, but I just put a SCT Livewire LS on this truck and found using the Street tune the fluttering all but goes away, until it gets to 6th gear. Even then, it sometimes won't flutter and I have to back off because of excessive speeds.
I setup the TS to show boost pressure and can see a drop to near zero when the flutter happens, and this is under full throttle or at least a good amount of throttle.
Anyone had this problem or have an idea what might be causing this?
Sounds like you vains could possiably be stuck
I would venture to say you're having your VGT veins sticking.
Sent from AutoGuide.com App
Could be a VGT selenoid problem, could also be a late 04 issue with the throttle body butterfly valve sticking of failing.
KA1 PRELIMINARY DIAGNOSIS
Key off.
Perform a visual inspection.
Key on, engine off (KOEO)
Retrieve and record any continuous and on-demand DTCs. Clear DTCs.
Run the engine until the engine temperature stabilizes.
Carry out the KOER self-test.
Verify EGR operation.
Are any DTCs present?
Yes No
For DTC P0299, P0478, P132B, P2262 or P2263, GO to KA2 .
For all other DTCs, REFER to Section 4 Diagnostic Trouble Code (DTC) Descriptions. GO to KA2 .
KA2 SCAN TOOL FUNCTIONALITY
Is the vehicle build date on or before 9-29-03? Yes No
GO to KA3 . GO to KA12 .
KA3 CHECK THE MANIFOLD ABSOLUTE PRESSURE (MAP) AND BAROMETRIC PRESSURE (BARO) SIGNAL ACCURACY
Inspect the MAP sensor hose and manifolds for damage, leaks, restrictions, and correct routing.
Disconnect the MAP sensor pressure hose from the sensor.
Install the pressure test adapter kit 014-00761 0-30 psi gauge between the MAP sensor and the pressure hose.
Access the PCM and monitor the MGP and EOT PIDs.
Allow the EOT to reach 70°C (158°F) and road test the vehicle. Does the MGP PID match the actual gauge pressure?
Yes No
GO to KA4 . GO to Pinpoint Test E .
KA4 CHECK THE ICP SENSOR FOR BIAS
Key on, engine off.
Access the ICP PID.
Is the ICP PID voltage between 0.18 and 0.24 volts? Yes No
GO to KA5 . INSTALL a new ICP sensor. KA5 CHECK FOR INPUT SENSOR BIAS
Access the MAF PID
Access the BARO and MAP PIDs for comparison. Refer to Section 6 for normal operating values.
Are the BARO and MAP PIDs within specifications and is the MAP and BARO PID values within 6.9 kPa (1.0 psi) of each other?
Yes No
GO to KA6 . REFER to the appropriate pinpoint test to continue sensor diagnostics.
KA6 CHECK THE TURBOCHARGER OPERATION BOOST
Key ON, engine running.
Access the PCM and monitor the MGP, EGR_DC, RPM and VGTDC PIDs. Access the PCM and control the EGRDC, RPM_DSD, and VGTDC PIDs. Increase the commanded engine speed to 1,200 RPM using output state control. The calibration may limit the actual RPM between 1,150 and 1,200 RPM. Decrease the EGR duty cycle to 0%.
Decrease the VGT duty cycle to 0%.
Record the MGP PID value.
Increase the VGT duty cycle to greater than 85%.
Is the MGP PID below 3 kPa (0.44 psi) at 0% VGT duty cycle and above 6 kPa (.87 psi) at 85% VGT duty cycle?
Yes No
GO to KA7 . GO to KA8 .
KA7 CHECK THE TURBOCHARGER OPERATION BACK PRESSURE Key ON, engine running.
Using the gauge bar, access the exhaust pressure sensor port.
Access the PCM and monitor the, EGR_DC, RPM and VGTDC PIDs.
Record the EBP_G PID.
Is the exhaust pressure gauge reading below 5 kPa (0.73 psi) at 0% VGT duty cycle and above 50 kPa (7.3 psi) at 85% VGT duty cycle?
Yes No
GO to KA9 . GO to KA8 .
KA8 CHECK THE CHARGE AIR COOLER, AIR INTAKE AND EXHAUST SYSTEMS FOR LEAKS
Key in OFF position.
Disconnect the hose from the EP sensor.
Plug the exhaust pipe.
Connect the Rotunda Smoke Machine, Fuel Evaporative Emission System Tester 218-00001 (522) or equivalent to the EP hose.
Fill the exhaust system with smoke.
Pressurize the exhaust system with 20 psi regulated air.
Disconnect the hose from the MAP sensor.
Connect the Rotunda Smoke Machine, Fuel Evaporative Emission System Tester 218-00001 (522) or equivalent to the MAP hose.
Fill the air intake system with smoke.
Pressurize the air intake system with 20 psi regulated air.
Check the air intake and exhaust systems for leaks.
Are any leaks present?
Yes No
REPAIR the leaks. REFER to Section 4, Performance Diagnostic Procedures if a driveability concern exists.
CLEAR the DTCs. REPEAT the self-test. GO to KA10 . KA9 CHECK THE VGT ACTUATOR STABILITY
Apply the parking brake.
Place the transmission in PARK or NEUTRAL.
Turn the A/C and defroster OFF.
Clear the PCM DTCs.
Access the PCM and monitor the IPR, MGP, EGR_DC, and VGTDC PIDs. Access the PCM and control the EGRDC PID.
Allow the IPR to stabilize.
Slowly press the accelerator pedal and hold for 5 seconds at each of the following RPMs:
1,500 RPM
1,800 RPM
2,000 RPM
2,200 RPM
2,500 RPM
2,800 RPM
Do the VGTDC and MGP PIDs remain steady at all of the RPMs?
Yes No
The turbocharger system is operating correctly. REFER to Section 4, Performance Diagnostic Procedures.
CLEAR the DTCs. REPEAT the self-test. GO to AK7 .
KA10 CHECK THE OPERATION OF THE VGT ACTUATOR
VGT Actuator connector disconnected.
Remove the VGT actuator from the turbocharger assembly.
VGT Actuator connector connected.
Key ON, engine OFF.
Access the PCM and control the VGTDC PID.
Apply light pressure to the cam follower (tip of the actuator), while commanding the VGT duty cycle and check for the internal valve movement. Increase the VGT duty cycle to greater than 70%.
Is any internal valve cam follower movement present when the VGT duty cycle is increased?
Yes No
GO to KA11 . GO to AK2 .
KA11 CHECK THE VGT VANE OPERATION
Install the VGT actuator in the turbocharger assembly.
Remove the pipe plug from the top of the VGT actuator housing, located near the oil supply tube.
Apply an index mark on the internal valve cam follower (tip of the actuator). Key ON, engine running.
Increase the VGT duty cycle from 20% to greater than 85%.
Check the internal valve cam follower for movement at each step while increasing the duty cycle.
Is any internal valve cam follower movement present in each step when the VGT duty cycle is increased?
Yes No
CLEAR the DTCs. REPEAT the self-test. INSTALL a new turbocharger assembly. REFER to the Workshop Manual Section 303-04D Fuel Charging and Controls — Turbocharger.
KA12 CHECK THE ICP SENSOR FOR
BIAS
Key on, engine off.
Access the ICP PID.
Is the ICP PID voltage between 0.15 and 0.35 volts? Yes No
GO to KA13 . INSTALL a new ICP sensor.
KA13 CARRY OUT THE EGR TEST
Note: Incorrect EGR valve operation may affect turbocharger diagnostics.
Using the scan tool, carry out the Powertrain Air Management Exhaust Gas Recirculation (EGR) System Test. Refer to Section 4, Performance Diagnostic Procedures, Exhaust Gas Recirculation (EGR) System Test.
Is a concern present?
Yes No
Repair as necessary. CLEAR the DTCs. REPEAT the self-test. GO to KA14 .
KA14 CARRY OUT THE TURBO BOOST TEST
Using the scan tool carry out the Powertrain Air Management Turbo Boost Test.
Are any concerns present?
Yes No
For BARO sensor failure, GO to H .
For EP sensor failure, GO to X .
For MAF sensor failure, GO to J .
For MAP sensor failure, GO to E .
For all others, GO to KA15 . GO to KA15 .
KA15 CARRY OUT THE TURBO VVT TEST
Test.
Are any concerns present? Yes No
GO to KA16 . GO to KA17 .
KA16 CHECK THE OPERATION OF THE VGT ACTUATOR
Key ON, engine OFF.
Yes No
GO to AK2 . REMOVE the turbocharger. CHECK the turbocharger housing, vanes and unison rings for coking deposits. CLEAN as necessary. INSTALL the turbocharger and CHECK for correct operation. If the concern is still present, INSTALL a new turbocharger assembly. REFER to the Workshop Manual Section 303-04D Fuel Charging and Controls — Turbocharger.
KA17 CHECK THE CHARGE AIR COOLER, AIR INTAKE AND EXHAUST SYSTEMS FOR LEAKS
Yes No
CLEAR the DTCs. REPEAT the self-test. The turbocharger system is operating correctly. REFER to Section
3, Symptom Chart Index.
Check the MAP hose and manifold fitting for damage or blockage and MAP sensor wires/plug for damage. Check the EBP tubing for blockage and EBP sensor for wire/plug damage. Check proper operation of throttle body butterfly valve or remove butterfly valve. Sometimes the throttle body actuator fails or has wire damage and will cause the butterfly valve to close. By removing the butterfly valve, you eliminate the restriction.
Do you have a friend with an 03-07 superduty? If so, pull yours and his VGT solenoid and swap them. Then take your truck for a ride. If the flutter goes away, buy a new VGT solenoid. If it doesn't, look into cleaning the unison ring and vanes or as Rich eluded, check your butterfly valve under your intake elbow.
The only reasonable thing I think to do is remove the turbo and check it out and clean it up. Most likely it's only a days job and it will be off my mind and problem will be gone.
Lots of changes coming to this truck over the next few months. As I mentioned, it's one of my work trucks, but I am taking it back from the company. I'm going to buy a newer 5th wheel camper and this truck will undergo a full facelift, top to bottom. It will be fun and practical as newer trucks like I would want are nearly 30 grand these days. So, I'll spend 5 to 10 grand on this one and it will be a one-of-a-kind, which I will like even more.
Thanks for all the replies and helps guys.
1 - 12 of 12 Posts
