I'm looking to flush out my radiator before to long, i was just wondering what kind and how much coolant should i put back into the system. I've heard about this Valvoline G-05 Cooland, is it any good?
i used the ford yellow coolant. Thats what yours has in it now. you can replace it with the yellow but you NEED to still add the sca additive, even though fors says you dont. It took 2pints for mine to get up to par. Ive heard the CAT ELC is about the best. You have to get darn near every drop out of your system to get the full benefit. I believe it is a 300k coolant and needs zero additive. If i were to do it over thats the route id go
Ok so the Ford coolant is probably the one i'm going to use to put back in then, but i was wondering, how do you test the coolant for SCA's?? And where can i buy the additive.
